Arduino Forum
Using Arduino => Introductory Tutorials => Topic started by: ElectricLove on Feb 11, 2019, 10:44 pm
Title: Timing of various functions on ATMEGA 328P chip (Arduino Uno, Arduino Nano, etc)
Post by: ElectricLove on Feb 11, 2019, 10:44 pm
Hi, I spent some time today with my Oscilloscope and testing various functions of the ATMEGA chip.  I thought it would be worth it to someone else out there for me to share my findings.  These are taken with TekTronix TDS 2024C Oscilloscope, I used a digitalWrite (pin, HIGH); digitalWrite (pin, LOW); sequence to serve as the time marker and then just ran various sequences after that in order to see how long it would take to repeat the digitalWrite(pin, HIGH) command...  Since this allows for a detectable signal by the scope.
Pretty basic stuff and if anyone is interested in a more advanced functionality/sequence I'd be happy to test for you!
Here are the results:
Execute a digitalWrite(pin, value); ~4.1uS
Execute a digitalRead(pin); ~7uS
Execute a Serial.print(""); ~4uS PLUS ~1.04mS per character printed (example; Serial.print("hello"); 5 characters so it takes ~5.204mS.   NOTE: same timing regardless of baud-rate
Execute analogRead(pin); ~112uS
Execute analogWrite(pin, value); ~8.4uS
Generate a random number; random(); ~50uS
Execute math functions; examples; INT =+ 1, VAR = sqrt(VAR), cos(), sin(), tan(); no perceptible time change
Title: Re: Timing of various functions on ATMEGA 328P chip (Arduino Uno, Arduino Nano, etc)
Post by: AWOL on Feb 11, 2019, 11:06 pm
...but only if the transmit buffer is already full.
Not sure why it's the same value, irrespective of bit rate.
Need to try harder. You're fighting the optimiser.
Post by: Robin2 on Feb 12, 2019, 09:34 am
Please post the program you used to produce your results and explain how you use the 'scope to do the measurements
I would be interested to see the results for digitalWriteFast() and digitalReadFast() from the digitalWriteFast library (https://github.com/watterott/Arduino-Libs/tree/master/digitalWriteFast)
...R
Post by: larryd on Feb 12, 2019, 05:39 pm
...R
Here is one way to measure code timing:
https://forum.arduino.cc/index.php?topic=445951.msg3597772#msg3597772    (https://forum.arduino.cc/index.php?topic=445951.msg3597772#msg3597772)
(https://forum.arduino.cc/index.php?action=dlattach;topic=445951.0;attach=244494)
(https://forum.arduino.cc/index.php?action=dlattach;topic=445951.0;attach=244501)
Post by: Robin2 on Feb 12, 2019, 06:03 pm
Indeed. But how did the OP do it ?
...R
Post by: AWOL on Feb 12, 2019, 06:50 pm
...R
Post by: Robin2 on Feb 12, 2019, 07:09 pm
I'd prefer to see the OP's program and his/her own description of the timing process.
...R
Post by: ElectricLove on Feb 13, 2019, 08:21 pm
...R
The code is super basic; just activate the respective pins and run the short program.  I used the digitalWrite High followed by digitalWrite Low in order to create a visible time-stamp on the Oscilloscope, the length of that time-stamp also represents the amount of time it takes for a digitalWrite High...  digitalWrite Low command to execute.
Then I just put different functions in after that part of the code and used the scope to identify how much time between the peaks passed by, if it went from 4uS to 8uS then we can identify that it took 4uS for whatever was added to execute.
It is super basic but here it is...
pinMode(7, OUTPUT);
  digitalWrite(7, HIGH);
  digitalWrite(7, LOW);
  //WHATEVER FUNCTION WE ARE MEASURING TIMING OF
And, yes regardless of whether Serial.begin(value) is set to 9600 or 115200 or even 250000; the results of the timing of Serial.print(""); are the same...
I will try the digitalWriteFast commands and see what difference it makes.
Also; what do you mean by "fighting the optimiser" give me a math function to test and I'll be happy to see the effect...
Post by: Robin2 on Feb 13, 2019, 08:32 pm
If the compiler sees that the result of a calculation is never used it just leaves the calculation out of the code.
One way to deal with that is to declare your variables volatile as in
volatile int myVal;
...R
Post by: ElectricLove on Feb 13, 2019, 08:47 pm
...R
To test digitalWriteFast()
Executed the following code:
#include <digitalWriteFast.h>
#define PIN 12
volatile byte pin;
pinModeFast(PIN, INPUT);
pinModeFast(PIN, OUTPUT);
digitalWriteFast(PIN, LOW);
digitalWriteFast(PIN, HIGH);
pin = digitalReadFast(PIN);  // save a proper high/low value
And results are, wow it is WAY faster than a digitalWrite()
~504nS
I've attached a screenshot of the scope reading; I got a different scope yesterday which I am trying out today and so this is not taken on the TekTronix but is instead a Siglent SDS1104X-E; I double-checked for sanity that the digitalWrite(); function was still ~4.1uS as discovered previously.
Post by: AWOL on Feb 13, 2019, 08:52 pm
...or the compiler may simply substitute a constant, calculated at compile-time.
Post by: ElectricLove on Feb 13, 2019, 09:10 pm
So here is the updated list of values;
Execute a digitalWrite(pin, value); ~4.0uS
Execute analogWrite(pin, value); ~8.5uS
Execute math functions; examples; INT =+ 1, VAR = sqrt(VAR), cos(), sin(), tan(); ~250nS
Execute a digitalWriteFast(pin, value); ~500nS
Starting Loop() over; ~250ns
Post by: AWOL on Feb 13, 2019, 09:18 pm
Four cycles at 16MHz?
Dream on
Post by: ElectricLove on Feb 13, 2019, 09:29 pm
Dream on
What am I doing wrong?
I run this code:
#define PIN 14
  volatile byte pin;
  volatile int myVal;
  //myVal = tan(6000);
and get 500nS between the start of digitalWrite events (refer to attached image)
Then run this code:
#define PIN 14
  volatile byte pin;
  volatile int myVal;
  myVal = tan(6000);
and get 750nS between the start of digitalWrite events (refer to attached image)
Since the only difference is whether or the myVal = tan(6000); (and time is same even if it is tan(1)) that means that the action of myVal = tan(6000); took exactly 250nS;
How else would you explain this?
Post by: AWOL on Feb 13, 2019, 09:38 pm
tan(6000); is a compile-time constant, and you never use it.
You can verify this by looking at the compiled object code.
Please, start thinking.
Apart from not using code tags?
Post by: larryd on Feb 13, 2019, 10:29 pm
(http://forum.arduino.cc/index.php?action=dlattach;topic=597101.0;attach=294693)
Post by: AWOL on Feb 13, 2019, 10:44 pm
It would be good if you could eliminate the int to floating point conversion.
Post by: larryd on Feb 13, 2019, 10:52 pm
(http://forum.arduino.cc/index.php?action=dlattach;topic=597101.0;attach=294695)
Post by: AWOL on Feb 13, 2019, 10:59 pm
Thanks
Post by: westfw on Feb 21, 2019, 09:31 am
This is extremely unlikely, and does not match the behavior of a simple test sketch I put together:
  Serial.begin(256000);
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  Serial.println("hello");
  digitalWrite(13, LOW);
Post by: lastchancename on Feb 21, 2019, 10:17 pm
ASIDE:
This quite a useful discussion, despite the initial claims being questionable - it exposes the thinking and methods needed to optimise and understand the relationship between expectations and the results.
Compilers, optimisers and significant understanding is required before truly clean and efficient code can be delivered.
Thanks for starting the conversation OP !
Post by: Robin2 on Feb 22, 2019, 08:56 am
I agree this is an interesting and useful Thread.
However it does not seem to me to be appropriate for the "Introductory Tutorials" section. I can't imagine any part of this Thread being relevant to a newbie.
...R
Post by: westfw on Feb 22, 2019, 09:43 am
"How fast is an Arduino?" is a pretty valid newbie FAQ.
It's difficult to answer in a meaningful way, since most of the people who have to ask that question have an equally poor understanding of how fast a computer needs to be to accomplish particular tasks.  "Can by Arduino do two human-interface tasks at once?" is about as common as "What's the best camera for image analysis on my Arduino?"
Post by: lastchancename on Feb 22, 2019, 09:49 am
That last post throws me back to the early 80s...
Multi-processor 4MHz Z80 system running six users and printers with database, and menuing with character-based applications written in CB/86 !
Fast and reliable.
Each processor board running multi-user DR-DOS, had its own 64KB RAM, and shared access to parallel disks.
Those were the days.
Post by: Robin2 on Feb 22, 2019, 10:04 am
Perhaps. But I don't think a Newbie asking that question would find anything useful in this Thread. S/he would be expecting an answer in non-technical terms.
If I asked a 4 star chef if I would like spaghetti bolognaise I would not wish to receive a long diatribe on the ingredients in good quality spaghetti.
...R
