Arduino Forum
International => Deutsch => Topic started by: McKaiver on Feb 25, 2019, 01:17 pm
Title: Probleme mit TFT_HX8357_Due-master
Post by: McKaiver on Feb 25, 2019, 01:17 pm
Hallo,
Ich habe mir die TFT_HX8357_Due-master von Github besorgt und möchte sie natürlich auch auf nem Due laufen lassen...
IDE Version ist 1.8.1
Das Beispiel TFT_draw_JPEG gibt folgenden Fehler:
reference to'SD' is ambiguous
Arduino: 1.8.1 (Windows 10), Board: "Arduino Due (Programming Port)"
In file included from C:\Users\CurrentUser\Documents\Arduino\libraries\JPEGDecoder-master\src/JPEGDecoder.h:53:0,
                 from C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master\examples\TFT_draw_JPEG\TFT_draw_JPEG.ino:41:
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:62:3: error: 'SdVolume' does not name a type
   SdVolume volume;
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:70:33: error: 'SD_CHIP_SELECT_PIN' was not declared in this scope
   boolean begin(uint8_t csPin = SD_CHIP_SELECT_PIN);
In file included from C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master\examples\TFT_draw_JPEG\TFT_draw_JPEG.ino:41:0:
C:\Users\CurrentUser\Documents\Arduino\libraries\JPEGDecoder-master\src/JPEGDecoder.h:86:2: error: reference to 'File' is ambiguous
  File g_pInFileSd;
In file included from C:\Users\CurrentUser\Documents\Arduino\libraries\SdFat-master\src/FatLib/FatLib.h:27:0,
                 from C:\Users\CurrentUser\Documents\Arduino\libraries\SdFat-master\src/SdFat.h:33,
                 from C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master\examples\TFT_draw_JPEG\TFT_draw_JPEG.ino:35:
C:\Users\CurrentUser\Documents\Arduino\libraries\SdFat-master\src/FatLib/ArduinoFiles.h:122:7: note: candidates are: class File
 class File : public FatFile, public Stream {
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:28:7: note:                 class SDLib::File
 class File : public Stream {
C:\Users\CurrentUser\Documents\Arduino\libraries\JPEGDecoder-master\src/JPEGDecoder.h:86:2: error: 'File' does not name a type
  File g_pInFileSd;
C:\Users\CurrentUser\Documents\Arduino\libraries\JPEGDecoder-master\src/JPEGDecoder.h:139:20: error: reference to 'File' is ambiguous
  int decodeSdFile (File g_pInFile);
C:\Users\CurrentUser\Documents\Arduino\libraries\JPEGDecoder-master\src/JPEGDecoder.h:139:20: error: 'File' has not been declared
C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master\examples\TFT_draw_JPEG\TFT_draw_JPEG.ino: In function 'void setup()':
TFT_draw_JPEG:62: error: reference to 'SD' is ambiguous
   if (!SD.begin(SD_CS, SPI_DIV3_SPEED)) { // <<<<<<<<<<<<< On Due use SPI_DIV3_SPEED
C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master\examples\TFT_draw_JPEG\TFT_draw_JPEG.ino:36:9: note: candidates are: SdFat SD
   SdFat SD;                    // Permit SD function call compatibility with no sketch changes :-)
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:108:16: note:                 SDLib::SDClass SDLib::SD
 extern SDClass SD;
C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master\examples\TFT_draw_JPEG\TFT_draw_JPEG.ino: In function 'void drawJpeg(char*)':
TFT_draw_JPEG:80: error: 'class JPEGDecoder' has no member named 'decode'
   JpegDec.decode(filename, 0);
TFT_draw_JPEG:95: error: cannot convert 'uint16_t* {aka short unsigned int*}' to 'uint8* {aka unsigned char*}' in assignment
     pImg = JpegDec.pImage ;   // Decode a MCU (Minimum Coding Unit, typically a 8x8 or 16x16 pixel block)
Mehrere Bibliotheken wurden für "TFT_HX8357_Due.h" gefunden
 Benutzt: C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master
 Nicht benutzt: C:\Users\CurrentUser\Documents\Arduino\libraries\TFT_HX8357_Due-master_alt
exit status 1
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
Wenn nichtmal die Beispiele laufen, wie soll dann was anderes gehen?
Title: Re: Probleme mit TFT_HX8357_Due-master
Post by: postmaster-ino on Feb 25, 2019, 06:49 pm
Hi
"Die Referenz ist mehrdeutig"
Denke, Du bindest irgendwie eine Lib für eine SD-Karte ein und die TFT-Lib will 'irgend was Anderes'.
SO hast Du auch kein SdVolume, da eine SD-Karte nun Mal keinen Krach macht und somit kein Volumen benötigt.
Denke, wenn Du das Zeug einbindest, Welches die Entwickler ebenfalls eingebunden (und ggf. auch verlinkt) haben, wird auch das Beispiel zur Lib klappen.
... reiner Hüft-Schuss ...
MfG
Post by: Tommy56 on Feb 25, 2019, 07:03 pm
Eher ein Schuss in die Hüfte --> Hüfte kaputt: SDVolume ist eine Bezeichnung fürs Dateisystem. Die zugehörige Headerdatei in SdFat (https://github.com/Bodmer/SdFat/blob/master/SdVolume.h) ist als deprecated gekennzeichnet und hat einen #define error.
Gruß Tommy
Post by: postmaster-ino on Feb 25, 2019, 07:36 pm
Hi
Jesses :/ - SO kann man natürlich Volume auch sehen - ambiguous war mir irgendwie nicht eindeutig genug ;)
... humpele dann Mal weiter ...
MfG
