Arduino Forum
Topics => Robotics => Topic started by: akiskaps on Mar 20, 2019, 09:45 pm
Title: Arduino Drone (improve stability)
Post by: akiskaps on Mar 20, 2019, 09:45 pm
Hello, I have recently started building a drone using an arduino pro nano.The drone works well, but i am having a really bad time making the drone take off completelly vertically and stay completelly stationary while you do not use the remote control.Do you know any factor that plays role at drone's stability. Ι have tried to minimize the noise, that gyro read(mpu-6050), from the motors and the propellers by sticking tapes to them and helped a lot but still the drone is not so stable.Bellow is the hardware i am using because i am wondering if is it possible to have a really stable drone with those.
Hardware
1. 4* 1000kVmotor with 1045 propeller and 30A Esc
2. F450 chassis
3. arduino pro nano
4. mpu-6050
Thank you a lot for your time.
Title: Re: Arduino Drone (stability problem)
Post by: MartinL on Mar 21, 2019, 09:51 am
Hi akiskaps,
Have you activated the MPU6050 on-chip filter?
Ideally, it needs to be set at 20Hz.
Post by: akiskaps on Mar 21, 2019, 01:06 pm
Hi akiskaps,
Thank you for your answer!
Don't think so (the code is not mine), first time i hear this, can you give me more informations or a link?
Post by: MartinL on Mar 21, 2019, 01:19 pm
The MPU6050's Digital Low Pass Filter can be set in its configuration (CONFIG) register.
This is detailed on page 13 in the MPU6000 and MPU6050 Register Map Document: https://www.invensense.com/wp-content/uploads/2015/02/MPU-6000-Register-Map1.pdf (https://www.invensense.com/wp-content/uploads/2015/02/MPU-6000-Register-Map1.pdf).
Post by: akiskaps on Mar 21, 2019, 03:38 pm
Oh that is very interesting, there is allready a filter used in the code to reduce noise, so that's not my case. I just found that i have to calculate the correct PID values in order to have a more stable quadcopter. Does anoyone knows any other advice or tip on how to make a perfetly stable drone ?
Title: Re: Arduino Drone (improve stability)
Post by: Idahowalker on Mar 21, 2019, 06:53 pm
Perfect, good luck with that.
You might want to look into what a Optical Flow sensor or a TOF can do for you in relation to stability of a drone.
Post by: akiskaps on Mar 22, 2019, 05:46 pm
I searched for those terms and i am prety confused...
Is TOF like ultrasonic sensor? Optical Flow sensor seems to stabilizes the drone very well but i couldn't find any to buy except one brand that is really expensive. Can you suggest me any ?
Thanks a lot for the info!
Post by: Idahowalker on Mar 22, 2019, 11:43 pm
entering "time of flight sensor" into my favorite search engine nets all sorts of information on TOF sensors.
I like the TFMini but I use it for LIDAR imaging.
