Arduino Forum
Using Arduino => Programming Questions => Topic started by: mattlogue on Apr 18, 2019, 04:16 am
Title: Error: expected '}' before '{' token
Post by: mattlogue on Apr 18, 2019, 04:16 am
There clearly is a '}' at the end of that first line! Its a 5x35 array. Compiling for an ESP12E. I know i shoud not use String, but is it worse than using char pointers in unallocated mem blocks...
const     String    eAddrNames[5][EADDR_SZ] = { { "RESERVED" }
                        { "dailyEmails", "emailsCount", "fanEvery", "fanFor", "fanMode", "fanPostMixTime", "fanTimeout", "HHOffset", "hysteresis", "lastEmailHour", "lastIssueCodeI", "minsFan", "minsCool", "minsHeat", "lock", "MMOffset", "temperature", "temperatureSet", "tempX", "timeBlocks", "tempTimeout", "timeNTP", "lastVersionDayA", "version2A", "version3A", "lastVersionDayB", "version2B", "version3B", "RESERVED_INT", "RESERVED_INT"}
                        { "unlockTime", "codeMS", "epoch", "longmillis", "lastEmailMS", "lastIssueMS", "myResetMS", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG" }
                          { "APPass", "ATTPass", "BIPass", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10" }
                          { "RESERVED_STRING20", "RESERVED_STRING20", "RESERVED_STRING20", "RESERVED_STRING20" } };
Title: Re: Error: expected '}' before '{' token
Post by: GoForSmoke on Apr 18, 2019, 04:38 am
troll
Post by: mattlogue on Apr 18, 2019, 04:48 am
That's hardly helpful.
Post by: Montmorency on Apr 18, 2019, 05:25 am
Um, aggregate initializers are supposed to be separated by commas. Where are your commas?
const String eAddrNames[5][EADDR_SZ] = { { "RESERVED" }, // <- comma
      "version3B", "RESERVED_INT", "RESERVED_INT"}, // <- comma
      // and so on
Post by: mattlogue on Apr 18, 2019, 06:14 am
I missed the commas between the dimensions. Darn, thanks!
Post by: GoForSmoke on Apr 18, 2019, 12:40 pm
because whatever you do, don't define char arrays then use those or even more, don't put const chars in PROGMEM.
Load up your RAM with data you already have a copy of and be sure to use C++ convenience objects to trash the heap.
Post by: mattlogue on Apr 18, 2019, 01:17 pm
Yep
Post by: GoForSmoke on Apr 18, 2019, 01:23 pm
You should know better after all this time, hence Reply #1.
I'm hardly helping you shoot your own foot. Noted.
