Arduino Forum
Using Arduino => Microcontrollers => Topic started by: manoj_gudi on Dec 22, 2011, 06:41 pm
Title: ATmega168A PU
Post by: manoj_gudi on Dec 22, 2011, 06:41 pm
Hello,
I'm quite new to Arduino, I have one Freeduino(16Mhz) and I use that to boot load other micro-controllers using ICSP pins.
I use ZF-007 ISP programmer to burn hex files of boot loader on micro-controllers. I've tried burning ALL boot loaders(given by Arduino for 168 controllers) on my new ATmega168A-PU, it writes flash memory successfully, but when I remove the ISP and attach USB cable on Freeduino, it is not loading.
I have read ATmega168A PU data sheet and for 4.5 to 5.5 voltages it supports clock with maximum frequency 20Mhz
I am not able to locate the problem which is frustrating.
Any help will be appreciated...
Title: Re: ATmega168A PU
Post by: Grumpy_Mike on Dec 22, 2011, 07:12 pm
The processor does but not the boot loader unless you get a special 20MHz one.
Post by: cmiyc on Dec 22, 2011, 08:11 pm
Is there an error message?
Which board are you selecting in the Arduino IDE?
