Topic: Arduino library for WTV020-SD-16P audio module (Read 328554 times) previous topic - next topic
jmmerino
Hello everyone,
May be this is a silly question, but I'm a newbie so.. sorry in advance...
Can I have direct access to the SD card with the WTV020? I mean, read and write files directly with an SD card library like the SD.h...
I want to use this module for two things in my project:
1.- Play some music files
2.- Store some html files for a micro-webserver
Do you think that this is possible or I have to buy another SD card module to store the HTML files?
Thanks!
GoForSmoke
You can make an SD adapter pretty cheaply. Google DIY SD card
If your Arduino is 3.3V then you don't have to do any voltage leveling, otherwise you will need a small handful of cheap parts for leveling.
The neatest voltage leveling I've seen uses 3.3V pullups on the SD adapter input pins and diodes on the same pins blocking 5V input. It only wastes a little power on one line.
When a 5V line is HIGH, the SD card reads 3.3V HIGH pullup because the diode blocks the 5V.
When a 5V line is LOW, it takes the pullup current away through the diode and the SD card reads LOW.
Feed the SD card VCC from a voltage divider and use that same line to power the pullups through 10k resistors.
That's 2 resistors for VCC and a resistor and diode for MOSI, SCK and SS.
However you wire it, there are oodles of voltage leveling circuits and chips, the code will be the same.
In your IDE under File->Examples->  you should find the SD examples and they should run.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
roontoon
Can this module be controlled totally by the arduino? If so what can be eliminated from the circuit? The project that I have in mind for it will require that it operate and change recordings via the arduino. Thanks!
d
HazardsMind
Basically anything that uses a button can be replaced by the arduino. Volume, next/prev song, pause/play.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
roontoon
What about the schematic? Does the module only need the three connections to the Arduino and the rest of the schematic  can be eliminated? Or do you need additional pins  on the Arduino. Thanks
d
HazardsMind
Take a look at the attachment below. On page 5, it gives you a layout of what each pin does, and if you look at pin P04 and P05, you will see a secondary function. P04 is the clock, and P05 is the data, so with that, you basically only need two pins to get it to work, but you also need to send the correct data too.
The library was made to send said data, and all you need to do is wire it correctly.
My GitHub:
roontoon
roontoon
I am trying to get this working and I have a question re: schematic and sketch.  In the schematic it is showing only three pins on the arduino used. Pin 1 of the WTV020-SD-16P going to A3 on the Arduino, Pin 7 of the WTV020-SD-16P going to pin A4 of the Arduino, and Pin 10 of the WTV020-SD-16P going to pin 5 of the Arduino.
But in the sketch there are four pins defined. I wired it up as in the schematic but nothing is working.... What am I missing?
int resetPin = 2;  // The pin number of the reset pin.
int clockPin = 3;  // The pin number of the clock pin.
int dataPin = 4;  // The pin number of the data pin.
int busyPin = 5;  // The pin number of the busy pin.
Thanks
Dan
HazardsMind
P06 is the busy pin (pin 5), it lets the arduino know when a audio file has ended.
My GitHub:
roontoon
I guess I am confused about the reset which is defined in the sketch as pin 2 but in the schematic it is A3. And A3 in the sketch is defined in the sketch as the clock pin not the reset. Not clear to me at all.
d
HazardsMind
The pins used in the diagram are just examples, it's the pins in the code you want to go by. Then again, you could always changes those too, but as long as you know which pin is what (clk,data,reset and busy) you can code it to work on any combination of arduino pins. Just note, if you plan on using the serial monitor, don't have anything in digital pins 0 & 1 , otherwise you may get incorrect results.
My GitHub:
McTristan
Hello All,
this is my first post so don't kill me for asking.
I've got my module working fine with a 2GB Transcend SD card connected to a 3.3V 8Mhz Arduino Pro Mini. It plays every sound on the SD card but I have a kind of funny behavior: whenever I play a file (synchronously or asynchronously - it doesn't matter) it will play 2 seconds, rewind and play the whole song.
It will always do this and with every file - play 2 to 3 seconds, rewind, play the whole file without a problem...
Any ideas?
P.S: Of course I'm using the library from the first post...
McTristan
In case anyone wonders - I could solve the problem by applying the fixes mentioned here:
https://www.sparkfun.com/users/395251
insufficient delay after reset. In line 37, changing "delay(300);" to "delay(750);" worked for me;
if you rely on the playVoice() call: sendCommand() returns too soon, when the busy pin is not yet on. In line 94, tweaking "delay(20);" to "delay(50);" worked for me.
GoForSmoke
It might be better to watch the busy pin than to delay and assume readiness.
Best case with the delay is you wait every time longer than needed.
McTristan
Yes you are right but for the time being this single delay in the beginning is the easiest way. The documentation is so weird and the findings in this and other forums so different I won't believe a single thing ...
I'm using a Transcend 2GB Micro SD card which is said, does not work most of the time. I've tested it with 2 1.5V AAA batteries as well and it is working for hours together with the 3.3V Arduino Mini Pro ... . All this should not work reading this forum and the documentation ;)
