Topic: LOL - Exploded cap. (Read 10188 times) previous topic - next topic
cjdelphi
I have a circuit that powers a 11watt fluro tube from 12v, so i decided to have some fun and ramped it up to 16v, 20v, kept turning to max out this step up voltage regulator and i was starting to hit around 25volts
and BANG!!!!, the input capacitor exploded the whole house heard it, it was a 16v 10uf or pf, not sure, i replaced it with a 100pf 25v cap and cranked up the voltage to 22 volts getting a spark gap of around 6cm :D but anyway whatever happened it knocked out my computer (not even on the same circuit) reset my arduino (Which shared the same battery) something weird happened just before or just after huge amounts of energy for a brief moment was consumed my voltage regulator could not care less it seems must have spiked over 6amps which it was happy with, shame the voltage regulator powering the arduino could say the same, and as for why my computer died (power on, screen off) usb is not connected there's no shared link, it's isolated, but it was enough to make the arduino go spastic and tell me there's a power out (located about 1 meter away).
as for the bang, it's deafening not nice .... but sure was FUN!!!!
fungus
Yeah, those things are noisy when they go off.
dhenry
Exploding caps can easily take out an eye or two.
BulletMagnet83
What some of us used to do in college was to get some little 1 or 10uF electrolytics, put them inside a pen casing with the legs hooked up in reverse to a bench supply at full voltage, and use them as cannons to fire diodes across the room. A bit childish to say the least... but nobody died :)
JoeN
http://www.youtube.com/watch?v=9jDsNe_bmtE
3:40
I will never ask you to do anything that I wouldn't do myself.
cjdelphi
so what happens to all the stored energy? dissipated by heat?
DVDdoug
My guess is that the high-voltage arced back throught the power supply into your house-power, causing a power-line spike.
fungus
I've got a couple of 68000uF caps on the shelf. They look at least 20 years old, maybe more. We used to hold a couple of wires on them to charge them up then melt nails across the screw terminals on the top. Stuff like that. Here's one of them with a couple of normal size components for comparison.
One day a little 10uF electrolytic exploded quite close to me. The metal case flew across the room fast enough to flatten itself against the opposite wall (which means it must have been going about the speed of a bullet...)
Ever since then I've been too scared to charge the big one.
fungus
Heat+light+sound. A bit like an electric firecracker.
JoeN
oric_dan
Fun, but not as dangerous as back in the old days, when there were 500V plus
power supplies on TV sets, and the "diodes" were vacuum tube rectifiers, which
tended to croak a lot.
I once saw a rectifier short out, the plate glowed an intense red for a couple of
seconds, then the large METAL-case electrolytic cap [roughly 5" tall and 1.5" in
diameter] exploded, and the can flew up like a rocket and put a dent in the
ceiling.
BulletMagnet83
Ahaa, those good ol' pre-1960 murderboxes :D They definitely don't make 'em like they used to.
jrmcferren
I've had a few electrolytics pop in my time with electronics. First I had a power supply with a shorted pass transistor (linear regulator) and hooked up an old car clock. After trying to get it to work (not thinking of an overvoltage problem) the electrolytic popped. Second incident was with a power inverter. Plugged it in and the cheap capacitor popped immediately. I was lucky that they were enclosed in a device at the time as the first one definitely would have gone flying.
krupski
In high school (1970's) I once "plugged" several large (1000 uF) electrolytic caps into the outlets in the school metal shop. They shut off the circuit breakers at the end of the day, so the caps sat there until the next morning.
Next morning when the instructor turned on the breakers, all the caps exploded in a shower of paper shreds and smoking electrolyte oil!
Nobody ever found out who did it.........
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
liuzengqiang
krupski,
I hope your teacher catches you now that you confessed. On the other side of the fence, a retired colleague of mine used to charge up a large capacitor, realizing some of his students has fallen asleep during lecture, then discharged it with a metal piece. The loud bang woke up everyone, very angry. That's how he got back at the sleepers. I bet he'd use a ruler to slap them if they still allowed that. Waste of money, I say, to sleep in a classroom.
