Topic: IDE 1.5.1 (Read 15979 times) previous topic - next topic
Markus_L811
there is something wrong in the IDE
There are no Menueline and no Buttons and I get this error.
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Base.getBoardPreferences()Lprocessing/app/helpers/PreferencesMap;
   at processing.app.EditorLineStatus.paintComponent(EditorLineStatus.java:98)
   at javax.swing.JComponent.paint(JComponent.java:1029)
   at javax.swing.JComponent.paintChildren(JComponent.java:864)
   at javax.swing.JComponent.paint(JComponent.java:1038)
   at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1030)
   at javax.swing.JLayeredPane.paint(JLayeredPane.java:567)
   at javax.swing.JComponent.paintToOffscreen(JComponent.java:5131)
   at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1475)
   at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1406)
   at javax.swing.RepaintManager.paint(RepaintManager.java:1220)
   at javax.swing.JComponent.paint(JComponent.java:1015)
   at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:21)
   at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:60)
   at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:97)
   at java.awt.Container.paint(Container.java:1780)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
   at javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:694)
   at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:128)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Did someone has an idea, IDE 1.5 works normal.
whitewater
I get the same error.
cmaglie
Which IDE are you using (linux32/64, win or mac)?
C.
Markus_L811
Windows on an Win7 64bit
whitewater
Windows 8 64-bit.
hiduino
I have a similar type errors with Windows XP Pro SP3 and another Windows XP Home SP3.
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5124)
at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:278)
at javax.swing.JComponent._paintImmediately(JComponent.java:5072)
at javax.swing.JComponent.paintImmediately(JComponent.java:4882)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:826)
cmaglie
Ok ok! i found the problem!
It was my last windows build that contains an error, probably a not perfectly clean build environment (i should always clean before doing the actual build, my distraction sorry :()
I must setup a build-bot as soon as possible to avoid such errors in the future.
Uploading a fixed version right now, it will be available in a couple of minutes.
C.
cmaglie
here we go:
https://github.com/downloads/arduino/Arduino/arduino-1.5.1r2-windows.zip
please confirm if this solves your issues.
C.
hiduino
Yep, that fixed it for Windows XP Home SP3.
Markus_L811
Yes solve my problem on Win7 64bit
baltasar
Still not fixed the load examples problem from certain libraries I reported before if on preferences the default path to sketchbook is changed !!!
This is really anoying as I could load directly all my sketchs from the sketchbook menu insted of having to do "Open", browsing to whatever directory to load them.
whitewater
Solved the problem on Win8 64 bit.
io53
Not fun. (Newest from git, linux64)
ace4
here we go:
Sweet, fixed mine as well.
nickgammon
Cannot launch Due IDE 1.5.1 on OS/X (10.7.5):
Just downloaded a few minutes ago.
