Topic: My home automation (webserver + HTML control) (Read 12580 times) previous topic - next topic
warloofer
Hello,
I have been working for 1 months on my Arduino home automation.
What I'm doing is a arduino + ethernet working as webserver, and using HTML in order to control the variables on my mobile telephone.
It has now:
- RTC
- Ethernet (w5100)
- Digital light sensor
- Relay module
- Arduino Mega
- 5v power supply
There are other modules I want to use in the future as PIR, distance sensor, temperature, RF, etc. but my priority is to control my central heating and exterior lights.
I have the webserver working (after spend hours trying to run the string concatenation), you can see a screenshot of my mobile.
I will post as much as I can about the proyect, but I have a doubt:
- What's the maximum distance that arduino ethernet shield can send/receive data from router?
        I have connected it to the router and it works perfectly, but when I connect it throw a 20 meters ethernet cable, it doesn't (PC and TV work).
In order to debut the HTML, I have to connect it to the ethernet of my Laptop, and use the WIFI connection to share the webserver to the net.
Thanks in advance
Kong
I'm  also working on a similar project as you, hope to see some ideas from you!
For now, I've a Mega connected via I2C to the ethernet module (W5100 + arduino together), and the ethernet card has about 20 meter cable (cat 5e) to my router.
It's all working fine here, so I think the distance isn't the problem.
Maybe the power isn't enough? Have you tried a 7,5 volt power supply?
warloofer
I'm using a 5v power supply directly connected to 5V pin of Arduino (avoiding the power regulator in the arduino Mega card).
I have completted the code and it's working perfectly. I have attached it. Variable names are in spanish.
The workig is as follow:
- Initialize the RTC, ethernet, read variables from ROM (I store it in order to recover them when the power is out), light sensor... etc.
- Show HTML code
- When a string from Web browser is received, read this and change variables. Show updated web again.
- Each 50 seconds update Central heating status and light status, in order to put ON or OFF when they are in AUTO mode.
warloofer
What I would like to do now is to use a ring connection between some arduinos, because I want to control to much reles and I'm not able to pass all the cable throug the wall, so I will need to distribute some arduinos, connected in ring typology.
graynomad
http://ardweenet.robgray.com/index.php
Unfortunately it's not even close to being ready yet, but PCBs are being fabbed as we speak.
______
Rob
psyazax
check your network cabel
if the wiring is not in the right order its almost not possible to work over 10m
warloofer
Thanks, I will check the connectors.
Ring typology is an option, other one is the wireless (RF), but I think the last one would be unestable.
Another question:
┬┐There is any web where I can get my external IP through arduino web client?
(in order to send me when the IP change)
psyazax
you can see your public IP here http://www.myip.ru/en-EN/index.php
or just search on google https://www.google.com/search?q=my+ip
or here http://ivan.mk/ip
mkcinek
nice project, can you share your code pls?
thanks
zoomkat
#9
Dec 14, 2012, 12:37 am Last Edit: Dec 14, 2012, 12:39 am by zoomkat Reason: 1
I've got an arduino and mega with ethernet shields connected to my router thru ~50' of cat3 four conductor telephone wire wired as 10BaseT.
ITead
I think the IBorad Pro is very suit for the home automation project like this : )
http://imall.iteadstudio.com/development-platform/arduino/arduino-compatible-mainboard/iboard-pro.html
The board is ATMega2560 + W5100, with SD and XBee socket, many interface breakout for sensor module and display.  RTC onboard, and comes with Arduino MEGA 2560 bootloader.
