Topic: Iron man helmet faceplate and LED (Read 7943 times) previous topic - next topic
digitalfa
Hey guys i'm new to the Arduino and i have a Arduino Uno and i don't know how to write the code.
Can some pro please write me a simple code which turn 180 to open up the faceplate and LED turn off with a press of a button, then if press again it will turn back 180 counter clock wide to close the faceplate then turn on the LED.
johnwasser
#1
Jan 12, 2013, 12:28 am Last Edit: Jan 12, 2013, 12:32 am by johnwasser Reason: 1
const int servoPin = 2;
const int buttonPin = 3;
const int LEDPin = 4;
#include <Servo.h>
Servo visorServo;
  visorServo.write(0);  // Initial position
  visorServo.attach(servoPin);
  pinMode(buttonPin, INPUT_PULLUP);  // Connect button between pin and GROUND. LOW when pushed.
  pinMode(LEDPin, OUTPUT);
  digitalWrite(LEDPin, LOW);  // LED off
  static unsigned long lastPushedTime = 0;
  static boolean visorClosed = true;
  static boolean lastButtonState = HIGH;
  boolean newButtonState = digitalRead(buttonPin);
  // If the button is down and it has been a while since it was last down...
  if (newButtonState  == LOW && lastButtonState == HIGH && millis() - lastPushedTime > 100) {
    lastPushedTime = millis();
    if (visorClosed) {
      visorServo.write(180); // Open visor
      visorClosed = false;
      digitalWrite(LEDPin, HIGH); // Turn on light
    else {  // Viso is open
      visorServo.write(0); // Close visor
      visorClosed = true;
      digitalWrite(LEDPin, LOW); // Turn off light
  lastButtonState = newButtonState;
PeterH
johnwasser
tcengs
thread back from the dead, i am starting a similar project and the code provided works wonders , however i am trying to include a 2nd servo that moves in the opposite position as the 1st servo. i am new an dont know where to start. didnt mean to high jack
johnwasser
It's not hard to add a second servo:
const int servo1Pin = 2;
const int servo2Pin = 5;
#include <Servo.h>
Servo visorServo1;
Servo visorServo2;
 visorServo1.write(0);  // Initial position
 visorServo1.attach(servo1Pin);
 visorServo2.write(180); // initial position
 visorServo2.attach(servo2Pin);
   if (visorClosed) {
     visorServo1.write(180); // Open visor
     visorServo2.write(0);
     visorServo1.write(0); // Close visor
     visorClosed = true;
tcengs
its been 15 years since I've written code. Thanks for the quick reply
arielcosco
como hago para que el servo suba despacio en la apertura?
