Topic: External interrupt fires early? (Read 6804 times) previous topic - next topic
JChristensen
I have a 1 Hz square wave connected to INT1, free-running so it is asynchronous WRT the ┬ÁC. Using the following sketch, the interrupt appears to fire as soon as it's enabled; I consistently see 999 as the first number output. Then the time to the second interrupt varies, and is less than one second. I was expecting the opposite, i.e. the first number should be some random value less than one second, and then the rest should be one second apart.
I've been poring over the datasheet and I can't find anything that would indicate this behaviour, hoping someone can help. I've checked the interrupt flag (INTF1 in EIFR) to ensure it's not set going in, and it's not, have tried resetting it anyway, no joy, etc. etc.
#include <Streaming.h>    //http://arduiniana.org/libraries/streaming/
#define LED LED_BUILTIN
volatile boolean int1Flag;
boolean ledState;
void setup(void)
    pinMode(LED, OUTPUT);
    EICRA = _BV(ISC11);          //external interrupt 1 on falling edge
    EIMSK = _BV(INT1);           //enable external interrupt 1
void loop(void)
    if (int1Flag) {
        int1Flag = false;
        digitalWrite(LED, ledState = !ledState);
        Serial << millis() << endl;
ISR(INT1_vect)
    int1Flag = true;
Typical output that I see:
999
1652
2652
3652
4652
999
1056
2056
3056
4056
999
1841
2840
3841
4840
I would have expected:
652
1652
2652
3652
4652
56
1056
2056
3056
4056
841
1841
2840
3841
4840
fungus
Did you try setting the pin as an input and using the pullup resistor?
JChristensen
Yes I did, it didn't make a difference.
JChristensen
I also tried using an Arduino to supply the 1 Hz signal, same results. Would have been surprised if that had made a difference, but it eliminates another possibility, if a remote one.
Riva
what happens if you put varying length delays before enabling the interrupt, does that alter the 999 value.
JChristensen
Yes, for example, with delay(2000) instead, I get:
1999
2787
3787
4788
5788
Coding Badly
Board?  (I don't think that matters but, at this point, it's a good idea to assume nothing.)
JChristensen
Chip-on-a-breadboard with Optiboot, telling the IDE it's an Uno :D  Would be easy enough to try a real one, though.
Coding Badly
Try this...
    noInterrupts();
    EIFR = _BV(INTF1);
    interrupts();
JChristensen
Try this...
That did it! I had tried resetting the interrupt flag, and I had tried inhibiting interrupts, but I hadn't put them together. Investigating further, it sure looks like the act of enabling the INT1 interrupt causes the interrupt flag to be set. This code
boolean ledState;
uint8_t eifr1, eifr2;
void setup(void)
    cli();
    eifr1 = EIFR;
    eifr2 = EIFR;
    EIFR = _BV(INTF1);
    sei();
    Serial << "EIFR1=0x" << _HEX(eifr1) << " EIFR2=0x" << _HEX(eifr2) << endl;
void loop(void)
    if (int1Flag) {
        int1Flag = false;
ISR(INT1_vect)
    int1Flag = true;
results in
EIFR1=0x0 EIFR2=0x2
1321
2322
3322
4323
I also discovered that using the Arduino interrupt functions causes the same undesirable behavior as my original code, so I feel just a little better:
boolean ledState;
void setup(void)
    attachInterrupt(1, myInt1Handler, FALLING);
void loop(void)
    if (int1Flag) {
        int1Flag = false;
void myInt1Handler(void)
    int1Flag = true;
Coding Badly
That did it!
Wow.  That's strange.  And annoying.  I know some of the interrupt types are automatically cleared when enabled.  I wonder if External Interrupts work differently by design, accident, or mistake.
JChristensen
That did it!
Agree, not at all what I would have expected. Clearing on enable might make a little more sense. I wondered if it was some kind of latent thing, maybe while the bootloader did its thing or whatever, but it just doesn't make sense if the interrupt wasn't enabled along the way.
I sure appreciate your help on this one!
retrolefty
Does changing the interrupt direction to raising edge give the same behaviour?
Lefty
JChristensen
Lefty
Yes, I tried that too. Just verified it again as well.
I found these two comments in an application note, but they don't fit the scenario here. It looks to me like enabling the interrupt causes the interrupt.
4. When changing the ISCn bit, an interrupt can occur. Therefore, it is
recommended to first disable INTn by clearing its Interrupt Enable bit in the
EIMSK Register.
5. Before enabling an interrupt, it is recommended to clear the flag bit of the
corresponding interrupt because when the flag bit is set, the interrupt will be
triggered the moment we enable the interrupt.
JChristensen
AHA! That app note was right. Setting the sense control bit (ISCxx) causes the interrupt. Using the code below, I didn't see it earlier, but by adding delay(1) I see it now. Wasn't seeing it before no doubt because the code was picking up EIFR before the four clock cycles it takes to respond to an interrupt.
boolean ledState;
void setup(void)
    cli();
    delay(1);            //   <------- AHA!
    eifr1 = EIFR;
    eifr2 = EIFR;
    EIFR = _BV(INTF1);
    sei();
void loop(void)
    if (int1Flag) {
        int1Flag = false;
ISR(INT1_vect)
    int1Flag = true;
Output:
EIFR1=0x2 EIFR2=0x2
1909
2910
3909
4910
