Topic: how to do low voltage analog switching? (Read 10712 times) previous topic - next topic
gratefulfrog
Running those pots at 20mA when their absolute max rating is 11mA is a bad idea. Are you sure that you can't get a low enough resistance using 10mA?
Actually, in general I need the full current range of the Vactrols, 0 to 40mA... I hadn't realized that the digital pots were so limited. I just copied the circuit from the arduino examples page.
That is the key problem in my circuit: being able to use an Arduino to digitally control a variable voltage divider with 500kohm max resistance, through which an analog signal flows with +1.5 to -1.5v range.  Using PWM to control the LED brightness allowed me to do that, even if it was somewhat coarse, and the PWM whistle got into the audio somehow. The results were pretty good.
When I saw the digital pot example on the Arduino page, and tried it out, it seemed to work fine, even at 30+mA, so I thought that was a perfect way of eliminating the PWM and also using very few components since each digipot has 6 channels and can be controlled by SPI, requiring very few pins...
If I go the DAC route, then I guess the current to the LED will again be pulsed by the DAC? Or would the OP-AMP flatten then into a constant DC voltage?
I'm really perplexed now that the digital pots seem to be out of the picture.
Thanks,
Bob
gratefulfrog
I was thinking, could I not use the op-amp with the digital potentiometer voltage divider to keep the current output by the pot wiper very low, while controlling the output current through the LED as the voltage output of the pot divided by R?
Thanks,
Bob
Docedison
A plain voltage follower is easy to implement... With a digipot too... a selector guide should show an op-amp with that kind of drive. As a point of fact I have a video cable driver. An old one. is the Elantec EL2157, SOT-8 and 90 mA @ +12V V supply I'm quite certain although I haven't done the research beyond looking up that part... I bought several hundred of them as a joke ebay bid I thought would never work... It did. Video cable drivers are meant to drive 75 ohm cable at frequencies to several hundred MHz albeit at unity gain. They are only current sources this one will go from .1V to Vsupply{12V - 1.8V} or 10.2V... and supply better than 50 mA.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
sonnyyu
#33
May 09, 2013, 09:39 am Last Edit: May 09, 2013, 09:43 am by sonnyyu Reason: 1
FYI
Hi-end audio might use military grade relay for switch and motorized potentiometer for volume control.
motor potentiometer, Ebay
Need new one?
http://www.potentiometers.com/alps_motorized_rotary.cfm
There is a 1,200 piece minimum order requirement on all ALPS products.
dc42
Most op amps won't provide 40mA output current, especially quad ones. For 40mA output I would boost the op amp output using a transistor, as in the attached schematic.
DACs produce a steady output, not a pulsed output.
Another possibility is to reduce and smooth the PWM output using 2 resistors and a capacitor, and then use the same op amp circuit to feed the LEDs. But then you would need 15 PWM pins.
You could, but a DAC is a more obvious choice, and you can get octal DACs vs. hex digipots.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
gratefulfrog
Thank you for the circuit! I've looked at it but of course have more questions, sigh.  I tried to understand the circuit but I'm really only guessing...
  • Will the DAC + op-amp+transistor allow for the full current range through the LED, i.e. 0 to 40mA?
  • What type and value of capacitor would be needed at the DAC ref2 connection?
  • The DAC produces a variable voltage from 0 to 1 Volt?
  • Then the op-amp maintains that 0 to 1V on it's output, then the transistor amplifies the current?
  • The LED sees 5V input always?
  • But how is the current at the LED controlled?
Thank you again,
Bob
dc42
#36
May 09, 2013, 01:05 pm Last Edit: May 09, 2013, 01:10 pm by dc42 Reason: 1
    yes, in steps of 0.156mA
    0.1uF ceramic will be fine
    yes, if you apply 1V to the REF pins and don't enable the x2 amplifier when you send commands to the DAC, then it will produce 0 to 1V output
    the op amp maintains that 0 to 1V across the 25 ohm resistor, and nearly all the current in that resistor passes through the LED
    the transistor acts as a constant current source, so the LED drops whatever voltage it needs when passing that current. With that circuit and a 5V supply, up to about 3.5V max is available for the LED. I am assuming this is enough for your Vactorols.
    see above
    Thank you again,
    Bob
    [/list]
    gratefulfrog
    Wow!  That is such an elegant solution!
    Thank you SO MUCH !
    Last question:  Do you think that the circuit will actually work?
    I find it hard to believe that I can now actually understand all the things you've shown me. What a great learning experience this thread has been!  Maybe you should give up safety critical software and teach ;-)  (I used to work in ATC sw and knew a bunch of guys at a UK safety critical ADA house...;-)
    Thank you,
    Bob
    gratefulfrog
    Hello (again ;-)
    I've been studying the data sheet for the TLC5628C and am wondering how to control it from the Arduino?
    Is controlling it similar to that shown in the shift register example? using the SPI library? Or is there some other way?
    I see that it has a "clock" and a "data" pin, and then 2 pins called "Load DAC" and "Load" ?  I tried to understand the rest of the data sheet, but some pointers would be very helpful...
    I will have to use SPI to control 5 74HC595 shift registers and 2 TLC5628C DACs hopefully using SPI, but I cannot see how this works from the simple example on the Arduino tutorial page...
    Thanks again,
    Bob
