Topic: arduino yun sd card (Read 2699 times) previous topic - next topic
cfloryiv
Is it possible to "mount" the external sd card to the linux file system? I've seen some code about using UCI but am not sure about the exact syntax.
federicofissore
It happens automatically: once you've plugged it in, it will be mounted at /mnt/sda1
If it has an "arduino" folder and this folder has a "www" subfolder, you can also upload html files together with your sketch http://scuola.arduino.cc/courses/lessons/cover/b4EoRkV
