Topic: Wie Exosite Script auf °C ändern? (Read 1 time) previous topic - next topic
-Micky
Wie kann ich folgendes Exosite Script auf °C ändern? Ich kann das zwar wunderschön auf tempC ändern, also auf °C, seriell wird das auch angezeigt, nur Exosite gibt dann als Temperatur immer Null an.
Code: [Select]
Exosite Arduino Basic Temp Monitor 2 (updated to use Exosite library)
This sketch shows an example of sending data from a connected
sensor to Exosite. (http://exosite.com) Code was used from various
public examples including the Arduino Ethernet examples and the OneWire
Library examples found on the Arduino playground.
(OneWire Lib credits to Jim Studt, Tom Pollard, Robin James, and Paul Stoffregen)
This code keeps track of how many milliseconds have passed
and after the user defined REPORT_TIMEOUT (default 60 seconds)
reports the temperature from a Dallas Semi DS18B20 1-wire temp sensor.
The code sets up the Ethernet client connection and connects / disconnects
to the Exosite server when sending data.
Assumptions:
- Tested with Aruduino 1.0.5
- Arduino included Ethernet Library
- Arduino included SPI Library
- Using Exosite library (2013-10-20) https://github.com/exosite-garage/arduino_exosite_library
- Using OneWire Library Version 2.0 - http://www.arduino.cc/playground/Learning/OneWire
- Using Dallas Temperature Control Library - http://download.milesburton.com/Arduino/MaximTemperature/DallasTemperature_372Beta.zip
- Uses Exosite's basic HTTP API, revision 1.0 https://github.com/exosite/api/tree/master/data
--- USER MUST DO THE FOLLOWING ---
- User has an Exosite account and created a device (CIK needed / https://portals.exosite.com -> Add Device)
- User has added a device to Exosite account and added a data source with alias 'temp', type 'float'
Hardware:
- Arduino Duemilanove or similiar
- Arduino Ethernet Shield
- Dallas Semiconductor DS18B20 1-Wire Temp sensor used in parasite power mode (on data pin 7, with 4.7k pull-up)
Version History:
- 1.0 - November 8, 2010 - by M. Aanenson
- 2.0 - July 6, 2012 - by M. Aanenson
- 3.0 - October 25, 2013 - by M. Aanenson - Note: Updated to use latest Exosite Arduino Library
#include <SPI.h>
#include <Ethernet.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Exosite.h>
// Pin use
#define ONEWIRE 7 //pin to use for One Wire interface
// Set up which Arduino pin will be used for the 1-wire interface to the sensor
OneWire oneWire(ONEWIRE);
DallasTemperature sensors(&oneWire);
* Configuration Variables
* Change these variables to your own settings.
String cikData = "0000000000000000000000000000000000000000";  // <-- FILL IN YOUR CIK HERE! (https://portals.exosite.com -> Add Device)
byte macData[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};        // <-- FILL IN YOUR Ethernet shield's MAC address here.
// User defined variables for Exosite reporting period and averaging samples
#define REPORT_TIMEOUT 612000 //milliseconds  = 10 Min period for reporting to Exosite.com
#define SENSOR_READ_TIMEOUT 144000 //milliseconds  = 2 Min period for reading sensors in loop
* End of Configuration Variables
class EthernetClient client;
Exosite exosite(cikData, &client);
// The 'setup()' function is the first function that runs on the Arduino.
// It runs completely and when complete jumps to 'loop()'
 Serial.println("Boot");
 // Start up the OneWire Sensors library
 sensors.begin();
 Serial.println("Starting Exosite Temp Monitor");
 Ethernet.begin(macData);
 // wait 3 seconds for connection
 delay(3000);
// The 'loop()' function is the 'main' function for Arduino
// and is essentially a constant while loop.
 static unsigned long sendPrevTime = 0;
 static unsigned long sensorPrevTime = 0;
 static float tempF;
 char buffer[7];
 String readParam = "";
 String writeParam = "";
 String returnString = "";
 Serial.print("."); // print to show running
// Read sensor every defined timeout period
 if (millis() - sensorPrevTime > SENSOR_READ_TIMEOUT) {
   Serial.println("Requesting temperature...");
   sensors.requestTemperatures(); // Send the command to get temperatures
   float tempC = sensors.getTempCByIndex(0);
   Serial.print("Celsius:    ");
   Serial.print(tempC);
   Serial.println(" C ..........DONE");
   tempF = DallasTemperature::toFahrenheit(tempC);
   Serial.print("Fahrenheit: ");
   Serial.print(tempF);
   Serial.println(" F ..........DONE");
   sensorPrevTime = millis();
 // Send to Exosite every defined timeout period
 if (millis() - sendPrevTime > REPORT_TIMEOUT) {
   Serial.println(); //start fresh debug line
   Serial.println("Sending data to Exosite...");
   readParam = "";        //nothing to read back at this time e.g. 'control&status' if you wanted to read those data sources
   writeParam = "temp="; //parameters to write e.g. 'temp=65.54' or 'temp=65.54&status=on'
   String tempValue = dtostrf(tempF, 1, 2, buffer); // convert float to String, minimum size = 1, decimal places = 2
   writeParam += tempValue;    //add converted temperature String value
   //writeParam += "&message=hello"; //add another piece of data to send
   if ( exosite.readWrite(writeParam, readParam, returnString)) {
     Serial.println("Exosite OK");
     if (returnString != "") {
       Serial.println("Response:");
       Serial.println(returnString);
   else {
     Serial.println("Exosite Error");
   sendPrevTime = millis(); //reset report period timer
   Serial.println("done sending.");
 delay(1000); //slow down loop
String cikData steht bei mir nicht nur auf Nullen sondern hat eine gültige Nummer.
Micky
uwefed
#1
Nov 02, 2013, 09:59 am Last Edit: Nov 02, 2013, 10:03 am by uwefed Reason: 1
Ein bißchen Eigeninitiative ist schon gefragt.
Code: [Select]
Was glaubst Du?
Zuerst wird die Temperatur in °C gelesen, umgewandelt in °F, dann formatiert, zum restilchen String hinzugefügt und gesendet.
Wie hast Du es geändert?
Grüße Uwe
-Micky
Die hatte ich, hab das nur nicht mit hochgeladen. Sonst wüßte ich ja nicht da es nicht geht.
Code: [Select]
static float tempC;
    //tempF = DallasTemperature::toFahrenheit(tempC);
    //Serial.print("Fahrenheit: ");
    //Serial.print(tempF);
    //Serial.println(" F ..........DONE");
    String tempValue = dtostrf(tempC, 1, 2, buffer); // convert float to String, minimum
Micky
uwefed
Was steht im tempValue wenn Du das seriell ausgibst?
Uwe
-Micky
Code: [Select]
Celsius    18.00 C ..........DONE
Exosite OK
done sending.
Demnach sollte das ja stimmen.  Nur bei Exosite wird als Value 0 angezeigt.
Micky
uwefed
Du hast nicht auf meine Frage geantwortet.
Quote
Die Ausgabe die Du zitierst ist an einer anderen Stelle und gibt tempF aus.
Code: [Select]
Den einzigen Unterschied den ich sehe ist daß
tempF vom Typ static float deklariert ist während
tempC nur float.
Der Unterschied ist, daß tempC bei jedem Durchgang von loop() neu generiert wird und deswegen leer ist während tempF den Wert in loop() auch beim nächsten Aufruf beibehält.
http://arduino.cc/en/Reference/Static
Da das Auslesen des Sensors, Umwandeln in tempF und serielle Ausgabe nicht im gleichen Durchgang von loop() gemacht wird ist tempC bei der Ausgabe von exosite leer (aber nicht tempF da diese Variable vom Typ static float ist).
ändere
Code: [Select]
in
Code: [Select]
static float tempC = sensors.getTempCByIndex(0);
Grüße Uwe
-Micky
#6
Nov 03, 2013, 12:24 am Last Edit: Nov 03, 2013, 02:18 am by -Micky Reason: 1
Nö, so geht es nicht. Immer noch Value 0. Das hat mich aber dazu gebracht noch mal was anderes zu machen. Es funktioniert so:
Code: [Select]
static float tempC;
String tempValue = dtostrf(tempC, 1, 2, buffer); // convert float to String, minimum size = 1, decimal places = 2
Micky
