Topic: need code to Honeywell ASDXACX100PAAA5 pressure transducers. please hellllllllpp (Read 1 time) previous topic - next topic
vareun
please help me interfacing  Honeywell ASDXACX100PAAA5  pressure transducer with the arduino UNO. i'm making a vaccum and a air blower at the same machine. if anyone can help me in writing down the codes.  The data sheet for the pressure transducer is  http://www.farnell.com/datasheets/1676926.pdf . thankyou.
UKHeliBob
Do you need help or do you want the code written for you ?  You may be better off asking in Gigs and Collaborations http://forum.arduino.cc/index.php?board=26.0
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Grumpy_Mike
The sensor number you give does not match with any of the possibilities in that data sheet. In particular the third from the end should be either an S or a number indicating an address, without this vital information I can't tell you how to proceed.
vareun
it is actually a  Honeywell ASDX series pressure sensor. The link is here brother.
http://uk.farnell.com/honeywell-s-c/asdxacx100paaa5/sensor-100psi-absolute-axial/dp/1784661
thankyou.
vareun
i need the code written pal. as i'm new to arduino i'm trying to write a little by my own. but i'm really confused about these transfer functions etc :( help me plsss
vareun
Grumpy_Mike
Sorry it is the same problem, that page leads to a data sheet that can not be matched to the part number. To make matters worse it says in the summery on that page that it has an analogue output. So unless you know what sensor you are dealing with no one can help you.
I can help you write code however it is not possible for me to write it for you.
