Topic: Help in Pressure transducer coding... (Read 1 time) previous topic - next topic
vareun
For my air pressure pump project i'm trying to attach a positive pressure transducer to the system.one of my pal gave me a link and code for the listed sensor below. please help me as I'm trying to learn
http://www.farnell.com/datasheets/8723.pdf
the sensor he mentioned was a Free Scale MPX4115 .
I could not understand the code below even after referring  to the transfer function.
  /* get the pressure */
  val = analogRead(pressurePin);
  pkPa = ((float)val/(float)1023+0.095)/0.009;
  pAtm = kpa2atm*pkPa;
the whole code can be see in:
https://gist.github.com/csete/813836
and also is it possible for me to use the MPX4250 Sensor in the same code. if not what are the differences should be made???
http://www.farnell.com/datasheets/9703.pdf
arduinoadrian
You may get better answers if the post is moved to Science and Measurements
robtillaart
1  val = analogRead(pressurePin);
2  pkPa = ((float)val/(float)1023+0.095)/0.009;
3  pAtm = kpa2atm*pkPa;
line 1: reads the value the sensor returns 0..5V mapped upon a value of 0..1023
line 2: converts this value of 0..1023 to a KiloPascal - a unit of pressure
line 3: converts the KiloPascals to atmosphree by multiplying with a constant.
What part do you not understand.?
Quote
If the sensor has the same pressure to voltage transfer function => yes
else => no
2 answers in the gigs forum, please donate $2 to charity of choice ;)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
knut_ny
Select a sensor which has the connection u need.
(some measure relative P, others abs P)
The datasheet will give you the trsnsfer funtion needed to report correct P
Ny
