Topic: Help: How to connect many buttons on the bread board (Read 951 times) previous topic - next topic
abedhijazi
Hello, everyone
I am trying to connect 10 or 12 input buttons on digital Arduino Uno pins (from pin 2 to pin 13) the "processing" program  displays the pressed button id, i am using ( 10 K ohm from ground pin attached with every digital pin( could you please see how circuit looks like in the attached video)) , It seams that there is a problem with the power circuit,  because when i move the (5v and gnd wires) to the left side on bread board the buttons on the left side pins activated, and when i move them to the right side the pins on the right side activated.
I did attach a video of the circuit and the output on the laptop screen.
http://youtu.be/AlJlvo0nmzs
I will highly appreciate your advises that could help me solve this problem
Thank you
AWOL
Quote
Why use external pull-downs, when you've got built-in pull-ups?
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
groundFungus
I could not open the video as it is private.  It may be, from your description, that the horizontal (power rails) are split in the middle and require a jumper to connect them.  many breadboards are built that way.
abedhijazi
Thank you for Advises, I did tried many things to solve, including external and the built in transistors but that did not solve the problem, AWOL.
BUT Now It works according to your Idea groundfungus :) Thank you
