Topic: [OT] Buoni o cattivi ? (Read 3937 times) previous topic - next topic
testato
May 23, 2014, 02:44 pm Last Edit: May 24, 2014, 11:15 pm by Testato Reason: 1
Aiutatemi a capire, questi in quale lista li metteresti ?
Quote
Allowing Oracle to incorporate your contributions
Even though VirtualBox' source code is licensed to you under the GPL, it's not enough to submit your patches under the GPL. The Licensing FAQ will tell you more about how Oracle handles VirtualBox licensing.
In any event, if you like to contribute anything that is subject to copyright (text, media, or code), Oracle must be legally certain they can redistribute the code you have contributed to their own customers who have purchased closed-source editions of VirtualBox. In order to be able to accept your contribution, we must therefore ask you to do one of two things:
Fill out the Contributor's Agreement (CA) and send it to Oracle. With the CA, you give Oracle permission to use your contribution under licenses other than the main VirtualBox license. This is a once-in-a-lifetime event: once we have your CA, we will never again ask you to undergo any bureaucratic procedures, and all future contributions are covered.
If you don't want to sign such an agreement, you can alternatively submit your contribution under the MIT license. This is a liberal, wide-spread Open Source license that allows Oracle (and anyone else) to use your contribution in both open-source and closed-source projects.
Basically, the main difference between the two options is this: With the CA, a written statement is necessary, but then only Oracle is allowed to relicense your code (unless you give other people the same permission). With the MIT license, you save the paperwork, but everyone else can use your code as well. It's your choice.
- [Guida] IDE - http://goo.gl/ln6glr
- [Lib] ST7032i LCD I2C - http://goo.gl/GNojT6
- [Lib] PCF8574+HD44780 LCD I2C - http://goo.gl/r7CstH
gpb01
Oracle ? Senza dubbio tra i cattivi !  XD XD XD
Guglielmo
P.S. : Ma che c'azzecca con Arduino ???  :smiley-eek: :smiley-eek: :smiley-eek:
Search is Your friend ... or I am Your enemy !
testato
C'azzecca sul discorso della gestione OpenSource, parliamo di due societa', non di certo uguali, oracle lavora intorno ai miliardi di fatturato, Arduino intorno ai milioni di fatturato, ma che entrambe si forgiano dell'uso del concetto opensource, con differenti modi di vedere le cose.
Inoltre l'ho postato perche' si parla della gestione delle licenze, argomento che mai perdera' di interesse e di importanza.
Rispetta pienamente la GPL il far firmare quel documento ? Non credo.
PaoloP
Metterei [OT] davanti al titolo del Topic.
Mi piacerebbe conoscere la fonte di questa informazione.  :smiley-roll:
menniti
1.000.000 / 40 (prezzo medio delle board Arduino) = 25.000 pz, se non fanno almeno 100.000pz l'anno non possono riuscire a mantenere l'Azienda con sede italiana, perché le tasse al 65% li distruggerebbero.
Francamente gli auguro che di milioni ne fatturino molti di più, ma ritengo ragionevolmente che sui 4-5/anno dovrebbero starci senza problemi.
Comunque credo che tramite Camera Commercio on-line si dovrebbe risalire abbastanza agevolmente ai dati di fatturato, se non adirittura ai bilanci, delle Società italiane.
Manuale "Arduino e le tecniche di programmazione dei microcontrollori ATMEL"
http://www.michelemenniti.it/manuale_di_programmazione.html
http://www.michelemenniti.it/offerta.html
Articoli ElettronicaIN
http://www.michelemenniti.it/elettronica_in.html
nid69ita
Fatturato,  mica "Utili"   :smiley-mr-green:
Fossero milioni in Utili Massimo e il Team Arduino farebbero i salti di gioia  :D
my name is IGOR, not AIGOR
menniti
+1
PaoloP
Infatti l'Azienda è da Guglielmo.  :smiley-mr-green:
menniti
Mi riferivo alla fabbrica  ]:D
PaoloP
La fabbrica non è di Arduino. Credo sia un soggetto indipendente con un contratto di fornitura.  ;)
leo72
pare anche a me che SmartProjects sia un produttore indipendente
menniti
Allora Test si è sbagliato non sono milionari sono miliardari se non pagano le tasse italiane XD
krossk2
Ma quindi Arduino non ha sede legale in Italia? Soltanto la produzione è italiana?
"Se una cosa sembra troppo bella per essere vera, semplicemente... non è vera!"
Video demonstration of my DIY Dashboard OBDII
nid69ita
Se non mi sbaglio SmartProjects è italiana, almeno la fabbrica dovrebbe essere qui ad Ivrea.
