Topic: i2cRead failed (Read 5889 times) previous topic - next topic
mrmimi1900
#15
Jun 14, 2014, 10:15 pm Last Edit: Jun 14, 2014, 10:20 pm by mrmimi1900 Reason: 1
here seems to be a similar problem.
http://forum.arduino.cc/index.php/topic,132493.0.html
But GY521 board for MPU6050 seems to have already a 2.2K resistor.
http://www.ventor.co.in/index.php?main_page=product_info&products_id=369
Mimi
raschemmel
Yes. All you device should share ONE GND. The motor driver simply provides a computer controlled path to ground for the motor coils.
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
mrmimi1900
#17
Jun 21, 2014, 11:42 am Last Edit: Jun 21, 2014, 12:01 pm by mrmimi1900 Reason: 1
Hello,
I measured with an oscilloscope the SDA and SCL line of the mpu6050.
Please see attached image osz01.
Are these signals good?
At least mpu6050 seems to be alive.
When I turn on the motor mpu6050 does not deliver any curves.
Just flat lines with constant voltage. See image osz02
The arduino still receives "i2cRead failed".
Regards, Mimi
mrmimi1900
I could not control the noise from the "cheap" motors.
Finally I resolved the problem by using a (better?) motor from Pololu.
Robot is nearly balancing!
thanks for all support
Mimi
caymanguy
http://www.youtube.com/watch?v=kIss1mZJWPs
caymanguy
the modified version with LCD display
https://www.youtube.com/watch?v=uAcljpmfuh0
