Topic: Aurel RX 4MM5 433mhz Receiver (Read 3242 times) previous topic - next topic
bwww
Hello all,
I have spent so much time trying to figure out how to receive weather data over 433mhz on my Arduino-compatible Freetronics EtherTen (Uno compatible). I have tried everything I can think of, so I have come to ask for advice.
I am trying to recreate this project:
http://www.mattlary.com/2012/06/23/weather-station-project/
I am using the same receiver module and transmitter (Oregon Scientific sensor). I have soldered a wire antenna (165mm in length) to the antenna pin of the RX module.
I am not sure if I need any passive components between the RX 4MM5 and my Arduino-compatible board? Do I?
The signals I am getting are messed up. They are not being able to be decoded correctly. I have tested with multiple transmitters. None of their signals are being decoded correctly.
Any other advice would be much appreciated. I have completely run out of ideas!
Here is the RX 4MM5 datasheet:
https://www.dropbox.com/s/c67bq4jrvhjs24k/RX_4MM5%28full%29%20%281%29.pdf
This is the sketch I am running:
https://bitbucket.org/mattlary/weatherlogger/raw/974c775f5a69e8a4902715ae3d0a19ea2f00cb9d/Ook_OSV2.ino
This is the Arduino-compatible I am using (in case it makes a difference):
http://www.freetronics.com/products/etherten
jremington
What is the exact model number of your Oregon Scientific sensor? There are many OS sensors and so far, three different RF protocols in use.
bwww
I have a Oregon Scientific THGR122NX (which the blogger I linked to above used) and a Oregon Scientific THN132N. I cannot get either to be picked up.
All I get is "CRES" data, which I think is just the result of noise.
bwww
Do I need a pull-down resistor on the data pin? If I do, what value should I be using? I have tried some high Kohm resistors and it did not improve anything.
mauried
Try using this application.
http://www.osengr.org/WxShield/Web/WxShield-Downloads.html
Im running it on a Uno with a mix of V2 and V3 Oregon Sensors.
Works fine.
jremington
You can verify that the receiver is actually receiving signals by examining the output directly. Use an oscilloscope or a laptop audio in, with Audacity. Here are a couple of examples http://fredboboss.free.fr/?cat=290  http://rayshobby.net/?p=8827
