Topic: Project 01 - Resistor Issue (Read 802 times) previous topic - next topic
checkertaxi
We bought the starter kit for the holidays.  We started with project #1 with no success.  For some reason it works without the resistor in place (wire instead).  Once we add the resistor, it fails to work.  Any thoughts?
meteoros
are you using only one resistor?(i mean try other resistor to check if if the first is ok)check if you are using 220ohm resistor.
