Topic: Obstacle Avoiding Robot with L293D (Read 5852 times) previous topic - next topic
hasan_uckun
Mar 04, 2015, 02:39 am Last Edit: Mar 11, 2015, 02:04 pm by hasan_uckun
I want to make a Obstacle Avoiding Robot with Motor Shield L293D. I have 2 DC motors,one Ultrasonic sensor and one servo motor.
I have completed circuit but i have not found code for ardiuno.Please,can you help me? Actually,i found a code but it not working exactly.
The code:
#include <AFMotor.h>
#include <Servo.h>
#include <NewPing.h>
#define TRIG_PIN A4 // Pin A4 on the Motor Drive Shield soldered to the ultrasonic sensor
#define ECHO_PIN A5 // Pin A5 on the Motor Drive Shield soldered to the ultrasonic sensor
#define MAX_DISTANCE 200 // sets maximum useable sensor measuring distance to 200cm
#define MAX_SPEED 80 // sets speed of DC traction motors to 180/256 or about 70% of full speed - to get power drain down.
#define MAX_SPEED_OFFSET 40 // this sets offset to allow for differences between the two DC traction motors ****** from 20
#define COLL_DIST 10 // sets distance at which robot stops and reverses to 10cm
#define TURN_DIST COLL_DIST+10 // sets distance at which robot veers away from object (not reverse) to 20cm (10+10)
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE); // sets up sensor library to use the correct pins to measure distance.
AF_DCMotor motor1(1, MOTOR12_1KHZ); // create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor2(4, MOTOR12_1KHZ); // create motor #2, using M2 output, set to 1kHz PWM frequency
Servo myservo;  // create servo object to control a servo
int leftDistance, rightDistance; //distances on either side
int curDist = 0;
String motorSet = "";
int speedSet = 0;
//-------------------------------------------- SETUP LOOP ----------------------------------------------------------------------------
 myservo.attach(9);  // attaches the servo on pin 9 (SERVO_2 on the Motor Drive Shield to the servo object
 myservo.write(90); // tells the servo to position at 90-degrees ie. facing forward.
 delay(1000); // delay for one seconds
//---------------------------------------------MAIN LOOP ------------------------------------------------------------------------------
 myservo.write(90);  // move eyes forward
 delay(90);
 curDist = readPing();   // read distance
 if (curDist < COLL_DIST) {changePath();}  // if forward is blocked change direction
 moveForward();  // move forward for 1/2 second
void changePath() {
 moveStop();   // stop forward movement
 myservo.write(36);  // check distance to the right
   rightDistance = readPing(); //set right distance
   myservo.write(144);  // check distace to the left
   delay(700);
   leftDistance = readPing(); //set left distance
   myservo.write(90); //return to center
   delay(100);
   compareDistance();
void compareDistance()   // find the longest distance
 if (leftDistance>rightDistance) //if left is less obstructed
   turnLeft();
 else if (rightDistance>leftDistance) //if right is less obstructed
   turnRight();
  else //if they are equally obstructed
   turnAround();
int readPing() { // read the ultrasonic sensor distance
 delay(70);
 unsigned int uS = sonar.ping();
 int cm = uS/US_ROUNDTRIP_CM;
 return cm;
void moveStop() {motor1.run(RELEASE); motor2.run(RELEASE);}  // stop the motors.
void moveForward() {
   motorSet = "FORWARD";
   motor1.run(FORWARD);      // turn it on going forward
   motor2.run(FORWARD);      // turn it on going forward
 for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
   motor1.setSpeed(speedSet);
   motor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
   delay(5);
void moveBackward() {
   motorSet = "BACKWARD";
   motor1.run(BACKWARD);      // turn it on going forward
   motor2.run(BACKWARD);     // turn it on going forward
   delay(5);
void turnRight() {
 motorSet = "RIGHT";
 motor1.run(FORWARD);      // turn motor 1 forward
 motor2.run(BACKWARD);     // turn motor 2 backward
 delay(400); // run motors this way for 400ms
 motor1.run(FORWARD);      // set both motors back to forward
void turnLeft() {
 motorSet = "LEFT";
 motor1.run(BACKWARD);     // turn motor 1 backward
 motor2.run(FORWARD);      // turn motor 2 forward
void turnAround() {
 motorSet = "RIGHT";
 delay(800); // run motors this way for 800ms
AWOL
What does that mean?
Please remember to use code tags when posting code.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
TomGeorge
hasan_uckun,  what is your electronics, programming, arduino, hardware experience?
Just using someone else's sketch is looking for trouble as you do not know how it works.
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
And how are you powering the robot?
Thanks..Tom...... :)
Everything runs on smoke, let the smoke out, it stops running....
hasan_uckun
#3
Mar 11, 2015, 01:27 pm Last Edit: Mar 11, 2015, 02:04 pm by hasan_uckun
I want to write a code with Ardiuno Uno.I had changed the code which i wrote before.There is a problem.The problem is that if robot's motor catch a obstacle,motors always will run because sensor is not see the any obstacles which is behind the sensor.But i did not want this.I want to all motors stop and run backward until 1 second.What do i do?
Now,i have tried to work following code:
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
#define MAX_SPEED 180
#define COLL_DIST 40
#define TURN_DIST COLL_DIST +20
NewPing sonar(TRIG_PIN, ECHO_PIN);
Servo servo;
const int led = 15;
int curDist;
int speedSet = 0;
 pinMode(led,OUTPUT);
 servo.attach(9);
 servo.write(90);
 Serial.println(readPing());
 digitalWrite(led,HIGH);
 Serial.println("START FORWARD");
 accelerateForward();
 if (readPing()<COLL_DIST){
   Serial.println("Collision Detected");
   moveStop();
   changePath();
   compareDistance();
void changePath() {
 servo.write(20);
 delay(600);
 delay(600);
 servo.write(90);
 delay(600);
 servo.write(160);
 delay(600);
 delay(600);
 servo.write(90);
 delay(600);
   turnLeft();
   turnRight();
   turnAround();
int readPing() {
 delay(70);
 Serial.print(cm);
 Serial.println(" cm");
 return cm;
void moveStop() {
 Serial.println("Stopped");
 delay(800);
void accelerateForward() {
 Serial.println("Start Forward");
   motor2.setSpeed(speedSet);
void turnRight() {
 Serial.println("Turn Right");
void turnLeft() {
 Serial.println("Turn Left");
void turnAround() {
 Serial.println("Turn Around");
AWOL
#4
Mar 11, 2015, 01:37 pm Last Edit: Mar 11, 2015, 01:38 pm by AWOL
I want to write a code with Ardiuno.
it's OK - you don't have to ask permission.
And . . ?
What happened?
I can't think of many directional sensors that will detect objects placed behind them
(what about the code tags?)
hasan_uckun
#5
Mar 11, 2015, 01:40 pm Last Edit: Mar 11, 2015, 02:05 pm by hasan_uckun
you wanted to picture my circuit,but it not necessary i used ardiuno motor shield,i said before.
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
Servo servo;
const int led = 15;
int curDist;
int speedSet = 0;
servo.attach(9);
servo.write(90);
  moveStop();
  changePath();
  compareDistance();
void changePath() {
servo.write(20);
delay(600);
delay(600);
servo.write(90);
delay(600);
servo.write(160);
delay(600);
delay(600);
servo.write(90);
delay(600);
  turnLeft();
  turnRight();
  turnAround();
int readPing() {
delay(70);
Serial.print(cm);
return cm;
void moveStop() {
delay(800);
void turnRight() {
void turnLeft() {
void turnAround() {
hasan_uckun
#6
Mar 11, 2015, 02:00 pm Last Edit: Mar 11, 2015, 02:08 pm by hasan_uckun
And . . ?
What happened?
while the robot runs forward,sensor can not see the obstacles which is its the rightside and leftside therefore motor or wheels is being catched by the obstacle.
AWOL
Have you tried mounting the sensors lower down?
hasan_uckun
#8
Mar 11, 2015, 02:28 pm Last Edit: Mar 11, 2015, 02:31 pm by hasan_uckun
I had done but it was unsuccessful.Probably,i must solve writing as the code: if  sensor's datas(distance) are same,it's time motors stop and run the backward until 1 seconds.I wrote that but it was useless.I must cahange this code but what?
void accelerateBackward ()  {
  if (readPing()==readPing()){
  moveStop();
