Topic: opkg update does not work under wifi interface (Read 805 times) previous topic - next topic
aamirmahmood
Hello,
I am facing this problem that 'opkg update' gets stuck at downloading stage. The YUN is connected to the wireless router and internet connectivity is fine. I can ping downloads.arduino.cc.
(opkg update just displays the following line and stay there)
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.gz.
However, if I leave the YUN's wifi settings to default (i.e. YUN acting as AP), and connect YUN to the same wireless router through Ethernet opkg update works fine.
I am using OpenWrt - YUN version 1.5.3. built=Fri Nov 14 03:53:51 CET 2014. The other system info is:
Firmware Version:  OpenWRTYun Attitude Adjustment 1 / LuCI 0.11 Branch (0.11+svn10537)
Kernel Version:      3.3.8
any ideas?
jessemonroy650
::::SNIP::::
any ideas?
@aamirmahmood,
Any ideas about what? It appears you can download from the Internet. However, the description you have given seems normal. Downloading an update or upgrade can take between 2 and 20 minutes, depending on your connect. What should we have ideas about?
Jesse
Angelo9999
Hello,
how long did you wait before stopping the opkg process? Did it return some error?
https://github.com/sngl
