Topic: problem on uploading data using temboo to spreadsheet (Read 891 times) previous topic - next topic
absyarazizan
Jun 01, 2015, 09:16 am Last Edit: Jun 01, 2015, 10:34 am by absyarazizan
can anyone help me,im using code example that has been provided in the IDE which sending data from arduino into a google spreadsheet.When compile the code there is no error,but when i click the serial monitor it showing this error
Initializing the bridge... Done!
Running AppendRow - Run #1
Getting sensor value...
Appending value to spreadsheet...
Error
A Step Error has occurred: "An input error has occurred. RowData and SpreadsheetTitle are required.".  The error occurred in the Stop (Missing request parameters) step.
HTTP_CODE
i also has the TembooAccount.h file and all the detail..
can anyone suggest how can i solve this problem?
thnks (sorry for my broken english)
Angelo9999
Please remove asap the file you attached. It seems to contain your personal IDs for google spreadsheet.
About the problem:
Did you change anything on the original example sketch?
https://github.com/sngl
absyarazizan
oh thanks..
about the sketches i did not change anything,just putting my id and etc..
sonnyyu
