Topic: measuring TLC5940 heat (Read 389 times) previous topic - next topic
valerio_sperati
Hi all,
I'm using a TLC5940 (and Arduino NANO), for mastering in pwm 4 strips RGB led 12 volts.
It works.
Because I'm debugging the circuit, I would like to check the temperature
of TLC5940. Can you  suggest which external device I can use?
The only device I have till now is a common Voltmeter.
thanks a lot,
Valerio
valerio_sperati
Ops! I realised just now that my voltmeter has a temperature probe too!
Never used!
Grumpy_Mike
A good rule of thumb is literally your thumb. If you can't stand to hold your thumb on the IC then it is too hot.
MarkT
IR gun thermometers are perfect for this - and cheap these days:
http://www.ebay.co.uk/itm/Handheld-Non-Contact-IR-Laser-Infrared-Digital-Temperature-Gun-Thermometer-UK-/310646217329?hash=item4853f51a71
(Though I would avoid something quite that cheap, personally!)
