Topic: How to control one 16 segment LED (Read 1 time) previous topic - next topic
12458
Aug 11, 2015, 01:47 pm Last Edit: Aug 13, 2015, 10:15 am by 12458
Hello I want to control 1 16 segment led with the arduino mega. I do not know how. Please help me.
AWOL
#1
Aug 11, 2015, 01:52 pm Last Edit: Aug 11, 2015, 01:53 pm by AWOL
Spec?
Do you mean like a starburst character display?
12458
#2
Aug 11, 2015, 02:25 pm Last Edit: Aug 11, 2015, 02:27 pm by 12458
I do not know where is the datasheet as this is a part of a salvaged clock. Here is what it says on the side.
12458
Paul__B
OK, it is indeed a starburst display.
What you now need to know, is whether it is a common cathode or common anode display.  You should be able to probe out the connections and figure out which sort using the "diode check" function on a multimeter.  You may get good hints by Googling "starburst display".
I count 16 segments plus a decimal.
12458
AWOL
OK, start with 16 I/O pins set to output, each with a 330 ohm resistor.
12458
Isaac96
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
Paul__B
It has a common anode
So tell me, how did you figure it all out - Google or the meter?
12458
12458
Can I control it with this?
http://www.farnell.com/datasheets/8620.pdf
A6276SLW-T
Isaac96
Probably. That driver will sink current, and you need to make sure you have the right amount of power flowing through your LED.
12458
Does anyone know a IC that can control 16 segments and is through hole package(DIP)?
AWOL
28 pin ATMega 328P ;)
