Topic: Voltage Divider (Read 4273 times) previous topic - next topic
aarg
#30
Sep 18, 2015, 09:47 pm Last Edit: Sep 18, 2015, 10:02 pm by aarg
The purpose of this is to measure voltage and current from a 9V battery and the percentage of power remaining in the battery.
Well, how did you end up using 10k resistors? That won't load the battery very much. A weak battery will still show almost full voltage with that.
Also, to measure the remaining power, you must employ some mathematical battery model based on the voltage and current. The voltage is a function of current. So varying the voltage and current will not get you a single reading, it will give you a function (a curve). You can't do that with a simple voltage divider. You have to have a current sink, vary the current, and measure the resultant voltage.
That would give you a very good picture of the battery's health (you would still need a profile for the battery, because types differ).
On the other hand, a simple battery tester approximates those readings by choosing a point along the curve, using a fixed current sink (a resistor). So your talk about measuring the current is a huge "red herring" (irrelevant fact considered to be of paramount importance).
You really need to process this concept before you go on. If you really expect to measure battery capacity with 12 bit accuracy, the simple resistive divider will be a complete failure. In fact, even the first method can't be that accurate.
Also, there is some confusion in this thread about battery life. Are you considering making periodic measurements, or one measurement, or continuous measurement? Because the measuring device is measuring its own battery, then current consumption will be an issue. If not, then not really.
Perhaps I should have asked you for details of the implementation, rather than the purpose.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
dwightthinker
You might look into an analog switch method or even
a relay to do periodic sampling.
As an analog switch, you could use a P-channel mosfet
with its source on the 9V and the drain on the divider.
Put a 10K resistor from 9V to the gate.
Add a npn transistor from the gate to ground ( collector to gate ).
Put a 10K from a digital output port to the transistors base.
The transistor is just a level shifter.
Most P-channel mosfets have a low enough threshold that 7
volts should be enough to turn is on enough to keep it from
effecting a 10K or so divider, much.
7 volts is most likely the end of life of the battery, anyway.
 Dwight
Wawa
Do you have a sketch without Aref(a simpler one)?
Is this simple enough.
Don't expect it to be as accurate with default Aref.
Leo..
Code: [Select]
// 10k resistor from A0 to ground, and 10k resistor from A0 to +batt
int value;
float voltage; // converted to volt
  value = analogRead(A0); // read pin
  voltage = value * 10.00 / 1024; // convert to volt // change 10.xx slightly to calibrate
  // print to serial monitor
  Serial.print("The battery is ");
  Serial.print(voltage);
  Serial.println(" volt");
  delay(1000); // readout delay
SagarDev
But that Aref sketch shows an error in my IDE.
Shakespeare's pen is an Electronics Engineer's Soldering Iron...
Wawa
What is the error.
The sketch from post#25 and post#32 both compile without errors here.
Post a screenshot of the error.
Leo..
aarg
What is the error.
Leo..
Why a screenshot and not a dump? There is a huge button on the right hand side of the compile window, "Copy Error Message".
SagarDev
I compiled it and it shows-->
Arduino: 1.6.4 (Windows 7), Board: "Arduino Mega ADK"
sketch_sep19a.ino: In function 'void setup()':
sketch_sep19a:13: error: 'INTERNAL' was not declared in this scope
  enabled in File > Preferences.
Wawa
A Mega has two internal references. 1.1volt and 2.56volt.
Change (INTERNAL) to (INTERNAL1V1) when you use a Mega.
Leo..
SagarDev
Okay. How do I measure the percentage of power left?
aarg
Read reply #30. No, I mean actually read it.
dwightthinker
With an alkaline, you can't determine the percentage.
Do a search on the web for discharge curves of alkalines.
With a carbon/zink, the discharge voltage curve is relatively constant.
You can get an idea from voltage.
Many laptop batteries have a NVRAM of some type to keep the
history of how much current has been used and past response to
discharge or charge.
These are only estimates and can be as much as 50% off at times.
They are just numbers to make the user happy.
Dwight
Wawa
AFAIK, coulomb counters are reasonably accurate, but they rely on the user to fully charge and discharge the battery.
The counter could loose track of the charge with infrequent use (self-discharge) and top-up charges.
Leo..
dwightthinker
Leo..
Yep! Still more useful than trying to look at the voltage of an alkaline
battery. Their curve is almost flat until near the end of life then they
drop like a rock.
Not too useful to tell a person when to make plans to change the battery.
You can still give a warning that the battery is failing.
You can use a discharge curve but realize, that is with a constant current
load. If the load is changing or you turn the unit on or off without saving
some history, you won't be getting many useful readings.
Most rechargeable types of batteries also have a flat discharge curve.
Dwight
raschemmel
#43
Sep 21, 2015, 11:12 pm Last Edit: Sep 21, 2015, 11:12 pm by raschemmel
This is an awfully long thread for a "Voltage Divider". Has anyone mentioned Ohm's Law yet ?
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
raschemmel
Quote
I'm not sure that's even possible.
The battery voltage across a calibration resistor would read discharge current that could possibly be correlated to a known discharge curve or graph. Is the discharge linear or logrithmic ?
