Topic: SSD1306 OLED with potentiometer input and servo output (Read 1 time) previous topic - next topic
bigtoys
Hello All,
First time posting here and hoping for some advice. I'm trying to use a Nano, 10k potentiometer, servo, and 1.3" OLED display.
My goal is to display potentiometer percentage (0-5v on A0) on the SSD1306 OLED in percentage and control the servo with the same analog input. I have no issues doing this with the 16x2 LCD display. My only problem is using the SSD1306 OLED (libraries seem limited). All I need is numeric display and percentage sign. I've tried adafruit ssd1306 and GFX as well as OzOLED with no luck.
Am I missing something that is easily achieved or are the libraries out there not enough to complete this project? I am not well versed in C++ programming.
Thanks in advance, it is appreciated.
mikb55
Post a photo of the display showing the pinouts.
bigtoys
I'm using I2C to communicate. I had to change the address to 0X3C to make it work. Please see attached. Thanks.
mikb55
Have you been able to display any characters at all?.
Does this have a 3.3 or 5v interface? If it is a 3.3v interface, are you using level shifters?
bigtoys
Yes, I have. I can display using the generic adafruit library as well as the ozoled library.
mikb55
I'm guessing that you need some code to convert an int to a character array that is compatible with the driver.
TomGeorge
Everything runs on smoke, let the smoke out, it stops running....
