Topic: Establishing connection (using UIPEthernet library) (Read 1 time) previous topic - next topic
heini
I just started Arduino and wanted to test my first Ethernet project. Sadly I dont even get a simple connection to run :(
Im using a Arduino Uni with a ENC28J60 Network Module and the UIPEthernet library. Im pretty confident that the pins are connected correctly (SC to Pin10)
The red LED on D1 is turning on -there is no green LED :(
This is the code im currently using:
Code: [Select]
#include <UIPEthernet.h> // Used for Ethernet
byte mac[] = { 0x54, 0x34, 0x41, 0x30, 0x30, 0x31 };
IPAddress ip(192, 168, 1, 179);
EthernetServer server(80);
  Ethernet.begin(mac, ip);
  server.begin();
  debug();
  if (client)
    Serial.println("-> New Connection");
void debug()
    Serial.print("IP Address        : ");
    Serial.println(Ethernet.localIP());
    Serial.print("Subnet Mask       : ");
    Serial.println(Ethernet.subnetMask());
    Serial.print("Default Gateway IP: ");
    Serial.println(Ethernet.gatewayIP());
    Serial.print("DNS Server IP     : ");
    Serial.println(Ethernet.dnsServerIP());
If I try to connect to the IP, it just hangs ;(
If anyone can help me with this problem, I would really applicate it.
Thanks!
