Topic: PFC Cirrus II Flight Console - Flight Console (Read 519 times) previous topic - next topic
FlightSimUK
Converting Serial Port Device to USB Device.
Can anyone help me with the above. I want to program the MEGA board to be able to convert the Flight Simulator controls from this device.
I am aware that someone may have already completed this project.
I would welcome your feedback
Regards
Derek
Riva
Not knowing much about the console...
Are you saying the console has a 9 pin serial connector that is designed to plug into a PC and you want to be able to convert this so it uses a USB connection instead? If this is the case then you don't need Arduino as you can buy RS232/USB adaptors. Some are better than others so it might be worth looking for reviews.
Another option using Arduino would maybe be the Arduino Micro as it has native USB support and a USART port you could connect the console to (via a suitable adaptor). The Micro's USB connection can look like a serial port to the PC or it can also mimic a USB mouse/keyboard/joystick.
Don't PM me for help as I will ignore it.
