Topic: genuino 101 driver (Read 10342 times) previous topic - next topic
deiv23
I'm using windows 7 and running Arduino IDE 1.6.7.  I have installed the "Intel Curie Boards" package by Intel version 1.0.4.
In the device manager, under COM and LPT ports, GENUINO 101 appears with the icon indicating that the device is not properly configured
The hardware id of this device is:
USB\VID_8087&PID_0AB6&REV_8087
I tried to install the intc_serial.inf driver in
C:\Users\SUPERVISORR\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.4+1.14\drivers
and it can't be installed
How can I proceed to get this working? Thank you
deiv23
I have installed it in another windows 7 on a virtual machine and everything works ok.
I don't understand why it doesn't let me to install the serial port driver
facchinm
Hi deiv23,
the drivers should install correctly also on the physical Windows machine since they are signed and available for both 32 and 64 bit.
You could try changing the USB cable or the USB port as a last chance, but since the board appears on the Device Manager I believe it can be related with a messed-up Windows installation.
Hokahonay
hi
I had exactly this problem after buying a 101 and installing the curie core
the fix is quite easy, in Device Manager right click on the device and select Update Driver
when the search for driver window comes up click on Browse, set the directory to C:/ and let windows search for the driver. When it finds the driver click the Install button and all should be well, on mine in Arduino Tools/Ports the new serial port will be visible, select it and your ready to rock
hope this helps and good luck
Dave
wkdxoghdi
Download "'Intel Curie Boards' by Intel version 1.0.4 _ (Arduino 101)" on the Board manager on the Arduino window.
paul_larner
ive the same issues,none of the above work for me running win xp sp3,any ideas?
bbaltz
The process to install the drivers on XP takes some work but check this thread.
The folder names may have changed since this thread was updated.
MianQi
You need to add the Intel Curie Core to the Arduino Software (IDE). This simple procedure is done selecting Tools menu, then Boards and last Boards Manager.
Guide on installing additional Arduino cores is here:  https://www.arduino.cc/en/Guide/Cores
m3vuv
this is bs none of this works,still code 10 driver issues.
m3vuv
ballscrewbob
@m3vuv
Specific OS ?
Specific computer hardware (please dont say a win tablet or an android device) ?
Steps taken ?
Without SPECIFICS it is almost impossible to help anyone
My 101 had some initial driver issues but it didnt take me long to figure it out.
I downloaded the specific driver from INTEL (yes its is thier hardware) and once I had those in I re-installed the boards package in the regular IDE and my driver issues were fixed.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
m3vuv
ive several pcs ive tried it with,this one runs win7 64 its a dell inspiron 1720,installed the latest intel board drivers etc and done everything mentioned in the above posts,still no luck,im gonna thro the piece of garbage in the bin!.
ballscrewbob
#12
Aug 19, 2018, 01:38 pm Last Edit: Aug 19, 2018, 01:39 pm by ballscrewbob
That is quite odd as WIN 7 is usually more driver tolerant than 8 to 10.
Win 7 pro here.
So which IDE ? (Use the full IDE not the APP version)
Create Editor is quite driver friendly for the 101 so long as you say YES to the pop ups during the install of the plugin and my 101 works very well with that too (Win 7 and 10 using Chrome or Edge).
Can you provide a pic of the device manager COM & LPT PORT section ?
OR
The UNKNOWN devices section if the 101 puts itself there  ?
Should look something like this but maybe not as many active boards.
Or like the second picture if the 101 is not playing nice.
