Topic: MAX6675 with Due (Read 1 time) previous topic - next topic
egymeda
Hello, I'm using Type K thermocouple and it was working with Uno, now I'm trying the same code with same library with Due and I get the following error:
Arduino: 1.6.8 (Windows 10), Board: "Arduino Due (Programming Port)"
C:\Program Files (x86)\Arduino\libraries\max6675\max6675.cpp:9:24: fatal error: util/delay.h: No such file or directory
 #include <util/delay.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Due (Programming Port).
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
#include "max6675.h"
int thermoDO = 5;   // SO
int thermoCS = 6;   // CS
int thermoCLK = 7;  // SCK
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
  Serial.println("MAX6675 test");
  // wait for MAX chip to stabilize
  // basic readout test, just print the current temp
   Serial.print("C = ");
   Serial.println(thermocouple.readCelsius());
   delay(3000);
Attached is MAX6675-library-master that I'm using
Your help is appreciated :D
Albi142857
I have the same problem. How did you solved it?
Thank you
ard_newbie
#2
May 25, 2019, 11:18 am Last Edit: Jul 21, 2019, 03:44 pm by ard_newbie
Remove util/delay.h from the library, this is for an AVR but your board is an ARM.
https://forum.arduino.cc/index.php?topic=19963.0
