Topic: Contest MKR Broken? (Read 1 time) previous topic - next topic
Smebdy
I'm worried. I just plugged in my MKR, I it's barely used so far (I've done code, etc. on it, but no hardware) and it powers on but isn't detected by my computer. This is kinda stressing me out. Has anyone else had this problem, and is there a fix? NOTE: I am using a contest MKR1000. I have disconnected everything from it, still, nothing.
keebie81
double tap the reset button. Also verify that your usb cord isn't a power only cord
Smebdy
Ok, I know the USB is data, used it with another device, worked fine. ERMYGERSH! Pressed the button twice. THANK. YOU. Now I can continue using it!
keebie81
Awesome! I had the same issue trying bad code a few times and had found the double tap trick buried in another post
