Topic: arduino nano voltage limits (Read 973 times) previous topic - next topic
camilozk
Apr 26, 2016, 03:52 pm Last Edit: Apr 26, 2016, 03:53 pm by camilozk
hi!
even though arduino nano specifications says that "Input Voltage (limits) 6-20 V", I am using one with a 5V power supply. 4.88V to be precise
why is that?
septillion
Because you choose to do so?
Seriously, have you re-read your post? You state you are using it with something and then ask us why?
If you mean, can I use this with a 5V supply? Then yes, but connect it to Vcc/5V instead of Vin/RAW.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
Ralph_S_Bacon
Just be aware you can't plug in a 5v supply into the power socket on an Arduino board, it's not a high enough voltage. You must supply it to the Vin pin but be very careful - if you exceed 5v then goodbye Arduino.  :o
My YouTube Arduino Videos: https://www.youtube.com/RalphBacon
Arduino and electronics videos designed to get your project off the ground.
Dog Walking and Pet Sitting in Northampton: www.wagnificentpetcare.co.uk
septillion
@Ralph, nope... You must not apply 5v to the Vin/RAW but to 5V/Vcc. Vin/RAW is just connected to the barrel jack on a Uno. And here we talk about a Nano which has no socket.
And about the careful, yeah, you must not apply 12V no. But the ATmega has a maximum of 6V so you got some play. 20% play is quite a bit I would say.
Ralph_S_Bacon
Yes of course, otherwise it gets regulated just the same! Silly mistake, thanks for spotting it.
