Topic: Arduino Leonardo not uploading  (Read 1 time) previous topic - next topic
OneSelfLost
Hello,
I have an Arduino Leonardo which HAD a Dragino shield. This was working fine.
I removed the Dragino shield so I can use the Leo on its own, but now it's not uploading.
When I plug the USB into the Leo, it identifies as a Yun, and will not take sketches.
I tried to burn the bootloader, but it won't go.
Whenever I try to upload, it says:
"Forcing reset using 1200bps open/close on port COM21"
It scans the ports, kicks my port off, and fails the upload. Many times.  I tried pressing reset while this was happening and it doesn't help. If I unplug the usb and plug it back in during the scan, it finds it, then fails.
Any thoughts??
Any help is greatly appreciated.
Uploading blink:
Pressing the reset button during scan:
Code: [Select]
Forcing reset using 1200bps open/close on port COM5
PORTS {COM5, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
Couldn't find a Board on the selected port. Check that you have the correct port selected.  If it is correct, try pressing the board's reset button after initiating the upload.
Unplugging and plugging back it during port scan:
Code: [Select]
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {COM5, } => {COM5, }
Found upload port: COM5
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -V -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\Erik\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Thank you.
OneSelfLost
Holy heck I fixed it!
I used an UNO as ISP, wired into the Leonardos ICSP and burned the bootloader.
The Leonardo now programs over the USB as normal.
ITS ALIVE!
mketech
This worked for me as well.  I was mystified as I previously was uploading sketches without issue and suddenly it stopped responding during uploads.  It would run the last sketch just fine but just wouldn't load any new ones.
Thanks!
Phoenyx33
ITS ALIVE!
Could you possible send the details to me at phoenyx33@yahoo.com?
I was using the same combo and tried to update the Yun Shield but all I get is "programmer not responding" and a bunch of java exceptions.
ballscrewbob
@Phoenyx33
You may want to edit your post and remove your email address as it is likely to increase the amount of spam you get.
You might also want to add more details of your issue instead of a "me too" type question.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
