Topic: Master Slave Robot Troubles (Read 741 times) previous topic - next topic
13walkec
Hello All.
Quick background.   I'm working for my universities Research and Development Lab, we currently have a master slave robot that students have been working on for the past 4 or 5 years.  This wouldn't normally be a problem but the class that works on it is a semester long class so basic math tells me that there have been at least 8 different groups that have worked on this robot.  Needless today its not functional and its my job now to get it back to a state that the next group can focus on the "fingers" of the machine (the part that they can use to pick stuff up).  So I am re-wiring the robot and writing the code to get it to move in the X, Y, and Z axis based on the orientation of the slave robot.
Any way I have two of the three joints working and now I'm stuck on the rotational axis.  The problem I'm running into, or at least the problem I think I'm having is that the rotational axis has a continuous potentiometer and the pot that I am using to control it isn't a continuous pot.
The base only moves about 4 to 5 degrees in either direction.  Now if I hold the master pot at 1024 for a little bit the master will eventually "break away" from that narrow movement of 4 to 5 degrees and swing full 360 until it reaches that same 4 to 5 degree section again.
I'm watching the Serial Monitor and while the robot is swinging around it passes the value the master pot is as but keeps going and doesn't stop like it is supposed to.
When the slave robot is in that 4 to 5 degree sweep it goes from 0 to 1024 on the serial monitor, so that is why I think it is because of the continuous pot.  below is code
Code: [Select]
int xpot = A2;
int xvalue = 0;
int mastx = A3;
int mastxvalue = 0;
int pwm2 = 10;
int dir2 = 8;
int xvalue1 = 0;
  pinMode(pwm2,OUTPUT);
  pinMode(dir2,OUTPUT);
  xvalue = analogRead(xpot);
  mastxvalue = analogRead(mastx);
  Serial.print(xvalue); Serial.print("\t"); Serial.println(mastxvalue);
  delay(1);
  if (xvalue < (mastxvalue))
    analogWrite(pwm2,100);
    digitalWrite(dir2,LOW);
    else if(xvalue > (mastxvalue))
      digitalWrite(dir2,HIGH);
      else if (xvalue == (mastxvalue))
        analogWrite(pwm2,0);
        else;
CrossRoads
Get rid of the extra ( ) around mastxvalue, and the extra else;
Code: [Select]
else if(xvalue == (mastxvalue))  >> this has to equal just 1 number from 0 to 1023,  maybe broaden it to allow mastxvalue +/-5 or 10, and take away the same from the others?
if (mastxvalue <=5){ mastxvalue = 5;} // keep it from going negative
if (mastxvalue >= 1018){ mastxvalue = 1018;} // keep it from going too positive
if( (xvalue <= (mastxvalue-5)) ||  { // so can't compare to less than 0
else if(xvalue >+ (mastxvalue+5)) { // so can't compare more than 1023
else if( (xvalue >= (mastxvalue+5)) || (xvalue >= (mastxvalue-5)) { // 5 to 1018 range
Or something like that.
Don't need this
else;
