Topic: avrisp mkii and software Arduino (Read 3613 times) previous topic - next topic
GeertClaes
Hello,
Some years ago I bought myself a "avrisp mkii" usb programmer.
http://www.atmel.com/Images/AVRISPmkII.jpg
Is it possible to use the Arduino developer/programmer software for this programmer?
I know you can use the ArduinoUNO board to program other Atmel devices but I wonder if I can use the "avrisp mkii" programmer directly on this Arduino software.
Thanks for the answer.
Best regards, Geert
pert
Yes it's possible. There are a couple problems you might encounter if you're using Windows.
If you have used Atmel Studio you will probably have the Jungo driver installed which is not compatible with the Arduino IDE so you need to uninstall that driver and install the correct one(libusbk or libusb-win32).
The issue described in https://github.com/arduino/Arduino/issues/2986. I have found this solved by using the latest Arduino IDE or Arduino AVR Boards version but someone else said that didn't work for them. I have also been able to solve it by using the libusbk instead of the libusb-win32 driver. I also made a workaround for the issue:
https://github.com/per1234/Arduino-AVRISPmkII-fix
