Topic: Arduino Current Measurement_Which is best? (Read 911 times) previous topic - next topic
willerpw
Feb 24, 2017, 11:33 am Last Edit: Feb 24, 2017, 11:40 am by willerpw
Hi there,
So here's the story..... I'm in the process of building a Automatic generator controller. For this to work correctly I need to supply the Arduino with as correct a possible Voltage and Current value.
Voltage input is sorted and I'm fairly happy with its accuracy, using a 240-6V transformer, then rectifying to a suitable DC range.
Now the part where I'm not sure what is the best option.
I'm using a 100A-50mA Current Clamp. Since the analog inputs on the Arduino works by supplying a 0-5VDC input, I have to convert the 50mA output from the Current clamp to a 0-5VDC measurable value.
I've browsed the internet and all I could find was attached circuit "Capture".
Why can't I use a the a 130Ohm resistor in parallel with the sensor, This will cause a 6.522V potential to be created which I would then Rectify and Filter to give my Arduino a 5V input at 100A primary on the clamp?
I have attached a test circuit diagram "Circuit 2" which I ran on LT Spice.. Has anyone used a current clamp as such yet? and how was the accuracy?
Thanks for reading
willerpw
LT Spice Circuit attached
DrDiettrich
Of course you can use a resistor to convert the current into a voltage. But have a look at the data sheet, a current clamp may require a certain load for correct values. Also consider that 5V for 100A will result in only 5mV for 100mA. And consider that a rectifier outputs the peak voltage, which is about 1.4 times the effective AC voltage.
