Topic: MKR1000 Does not Work (Read 1 time) previous topic - next topic
voltage_at
Hi Guys,
After the first Installation from my MKR1000 on my PC an Sketch Uplad fails.
After Unplug an Plug in in my USB Port the MKR1000 doesnt react any longer!
The LEDs are green, but in my Device Manager no New Hardware came on.
An in the IDE is no Port Available.
Reset already done with Press twice and 30secs.
Can you Help me?
Thanks!
ballscrewbob
Having this moved to the MKR SECTION if the mods will be so kind.
Suggest you also visit more of the posts in that section too !
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
AndreaRichetta
@Voltage_at
this board worked in the past?
have you tried under Create Web Editor?
thanks
voltage_at
After the "Bootloader mode" everything works fine!
I never lost connection again!
Thanks 4 replys! :)
