Topic: Nextion Screens with Due (Read 844 times) previous topic - next topic
mushman
I have a 7" nextion screen that I would like to work with the Due .. I have tried the official library and also   the library by bborncr having made the recommended changes to the nextion.h file.  However, I have not been able to get this to work.
I have also tried a level shifter for the voltage; but this made no difference.
Has anyone got this working and if so; is there any working examples?
Or can anyone recommend a 7" touch screen that has a working library that I can consider purchasing instead of using the nextion screens?
Note: I have connected to a MEGA and this works fine!
mushman
For anyone interested in connecting a Nextion to a Due ... for the bborncr library I may have discovered that the assigned serial port for nextion was failing on its init.  This may be because I have not set it correctly in the header .. I have comment out the init and have executed serial1.begin(9600) in the setup then this library springs to life .. I have not done anything fancy as yet .. but so far it looks like it is now functioning.
joeblogs
how did you go with your screen
