Topic: Arduino004 and C string functions (Read 3627 times) previous topic - next topic
mrbbp
Hello, i've got some prob with the C++ string functions
my code worked well in arduino003 now, i've got an error
Quote
error invalid conversion from 'const char*' to 'char'
i think i understand what it mean but i don't know how to resolve the prob.
is it about my string copy ?
and how to modify the char type
Code: [Select]
// init poeme
int jour = 0;
int nJour = 17;
int mois = 2;
int an = 2;
char chaine[65] = " ";
char ligne[0x10] = "";
int jMax[] = {0,31,28,31,30,31,30,31,31,30,31,30,31};
const char *sJour[33] = {"", " premier", " deux", " trois", " quatre", " cinq", " six", " sept", " huit", " neuf", " dix", " onze", " douze", " treize", " quatorze", " quinze", " seize", " dix-sept", " dix-huit", " dix-neuf", " vingt", " vingt-et-un", " vingt-deux", " vingt-trois", " vingt-quatre", " vingt-cinq", " vingt-six", " vingt-sept", " vingt-huit", " vingt-neuf", " trente", " trente-et-un", " mille"};
const char *sMois[13] = {"", " janvier", " fevrier", " mars", " avril", " mai", " juin", " juillet", " aout", " septembre", " octobre", " novembre", " decembre"};
const char *sAnnee[8] = {"", ""," deux mille deux", " deux mille trois", " deux mille quatre", " deux mille cinq", " deux mille six"};
const char *sNomJour[7] = {"dimanche", "lundi", "mardi", "mercredi", "jeudi", "vendredi", "samedi"};
void setup (void) {
 delay(100);
void loop (void) {
 int i = 0;
 int j = 0;
 if (jour > 6) {jour = 0;}
 if (nJour > jMax[mois]) {nJour = 1; mois++;}
 if (mois == 2 && an == 3) { jMax[2] = 29;} else { jMax[2] = 28;}
 if (mois > 12) {mois = 1; an++;}
 // concatenation des chaines
 *chaine = " ";
 strcpy(chaine, sNomJour[jour]); // dimanche
 strcat(chaine, sJour[nJour]); // dix-sept
 strcat(chaine, sMois[mois]); // Février
 strcat(chaine, sJour[2]); // deux
 strcat(chaine, sJour[32]);// mille
 strcat(chaine, sJour[an]); // deux
 Serial.print(chaine);
 jour++;
 nJour++;
 // ecriture des lignes
 strncpy(ligne,chaine,16);
 if (strlen(ligne) >= 16) {
   ligne[16] = '\0';
 // ecrit la ligne
 Serial.print(ligne);
 delay(100);
 *ligne=" ";
 for (i=2; i<=4;i++) {
   strncpy(ligne,&chaine[16*(i-1)],16);
     ligne[16] = '\0';
   // ecrit la ligne
   delay(100);
   *ligne=" ";
i was just trying to understand a bit C, now it is C++ :'(
any solution or a begin of solution ?
regards
eric
mrbbp
#1
Apr 30, 2006, 05:39 pm Last Edit: Apr 30, 2006, 05:40 pm by mrbbp Reason: 1
Code: [Select]
char *chaine = " ";
char *ligne = "";
i've just changed these two line and take off any *chaine = " " or *ligne=" " in  the loop()...
but pb compilation on serial...
eric
admin
what do you mean with "but pb compilation on serial..." ?
massimo
mrbbp
#3
Apr 30, 2006, 08:04 pm Last Edit: Apr 30, 2006, 09:16 pm by mrbbp Reason: 1
i mean this :
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1146411379
but now i haven't got any prob with serial error... :-X
eric
mrbbp
#4
Apr 30, 2006, 09:13 pm Last Edit: Apr 30, 2006, 09:15 pm by mrbbp Reason: 1
I've tried this code
Code: [Select]
int ledPin = 13;
// init poeme
int jour = 0;
int nJour = 17;
int mois = 2;
int an = 2;
char *chaine = " ";
char *ligne = " ";
void setup (void) {
 pinMode(ledPin, OUTPUT);
void loop (void) {
 int i = 0;
 int j = 0;
 //*chaine = " ";
 jour++;
 nJour++;
   ligne[16] = '\0';
 // ecrit la ligne
 //Serial.print(ligne);
 delay(100);
 //*ligne=" ";
     ligne[16] = '\0';
   // ecrit la ligne
   delay(100);
   //*ligne=" ";
 digitalWrite(ledPin, HIGH);   // sets the LED on
 delay(1000);                  // waits for a second
 digitalWrite(ledPin, LOW);    // sets the LED off
no compilation error
done uploading
but nothing appear on the serial monitor window and no blinking led
what's wrong ?
regards
eric
mellis
#5
Apr 30, 2006, 10:35 pm Last Edit: Apr 30, 2006, 10:38 pm by mellis Reason: 1
First, you have the Serial Monitor Baud Rate set to 115200, right?
Also, you're not allocating any room for chaine and ligne, so when you strcpy into them, you're overwriting random bits of RAM, which tends to cause problems.  Try something like:
Code: [Select]
char chaine[100];
char ligne[100];
or, to allocate space and initlialize the strings:
Code: [Select]
char chaine[100] = { 0 };
char ligne[100] = { 0 };
or don't bother with strcpy or strcat at all and just print the pieces one at a time.
mrbbp
#6
Apr 30, 2006, 11:12 pm Last Edit: Apr 30, 2006, 11:17 pm by mrbbp Reason: 1
thanks for the tips mellis, but that doesn't solve my prob.
how can i "reset" my string in loop()?
if i write :
*ligne=" ";
i've got this error :
"ligne" is not a constant char*...
does it mean that the strcpy is only a copy of pointers and not a "physical" copy of char's array ?
i'm a bit confused!
if i compile with arduino003, that's works.
but not with arduino004...
eric
mellis
The strcpy() will "reset" the string.  I.e.
Code: [Select]
char foo[100];
 strcpy(foo, "hello");
 Serial.println(foo);
 strcpy(foo, "world");
will send:
hello
world
mellis
P.S.  The problem with
Code: [Select]
*ligne=" "; is that *ligne is a character (the same as ligne[0]), but " " is a string.  To create a character constant, use single quotes: 'a'.  Thus, to assign to a particular character of the string:
Code: [Select]
ligne[3] = 'b'; or
Code: [Select]
*ligne = 'b'; or even
Code: [Select]
*(ligne + 3) = 'b';  To "reset" the string in this way, you want to assign the character with ASCII code zero (not the character '0' which has ASCII code 48) to the first character in the string:
Code: [Select]
*ligne = '\0'; or
Code: [Select]
*ligne = 0;
mrbbp
:-* yesssss
i think, i've finally understood.
many thanks.
eric
