Topic: [Arduino004] serial error on PBG4 and osx (Read 3512 times) previous topic - next topic
mrbbp
Apr 30, 2006, 05:36 pm Last Edit: May 01, 2006, 12:33 am by mrbbp Reason: 1
hello
on my PBG4 with osx.4.6 (J2SE 5.0, FTDIUSBSerialDriver 2.0.1), i've received error when upload prog to arduino.
RXTX leds bright... i suppose the upload is ok.
Quote
Error inside Serial.<init>()
gnu.io.PortInUseException: Unknown Application
     at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:354)
     at processing.app.Serial.<init>(Serial.java:127)
     at processing.app.Serial.<init>(Serial.java:72)
     at processing.app.Uploader.uisp(Uploader.java:146)
     at processing.app.Uploader.uploadUsingPreferences(Uploader.java:78)
     at processing.app.Sketch.upload(Sketch.java:1689)
     at processing.app.Sketch.exportApplet(Sketch.java:1749)
     at processing.app.Editor$38.run(Editor.java:1866)
     at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
     at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
     at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
     at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Atmel AVR ATmega8 is found.
Uploading: flash
Firmware Version: 1.18
there is no other prog used the serial port as describe in precedent post
i use the setup command and reboot the machine (more exactly shut down and restart as Tom Igoe explain in the processing bug page)
i've tried a simple prog to send string throug serial.
no compilation error, good tranfer, but no blinking TX's led.
i was exciting by the new version, but now :-/ :-?
regards
eric
mrbbp
don't know why, it's work now.
no reboot... :o
eric
mrbbp
well...
serial is a bit "versatil".
- if i boot my computer with the arduino plugged, serial initialize correctly and serial monitor work fine.
if i unplugged the arduino card and plug again, even if i restart IDE, serial monitor doesn't work anymore with this message
Quote
     at processing.app.Serial.<init>(Serial.java:63)
     at processing.app.Editor.handleSerial(Editor.java:1397)
     at processing.app.EditorButtons.mousePressed(EditorButtons.java:373)
     at java.awt.Component.processMouseEvent(Component.java:5551)
     at javax.swing.JComponent.processMouseEvent(JComponent.java:3126)
     at java.awt.Component.processEvent(Component.java:5319)
     at java.awt.Container.processEvent(Container.java:2010)
     at java.awt.Component.dispatchEventImpl(Component.java:4021)
     at java.awt.Container.dispatchEventImpl(Container.java:2068)
     at java.awt.Component.dispatchEvent(Component.java:3869)
     at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
     at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3933)
     at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
     at java.awt.Container.dispatchEventImpl(Container.java:2054)
     at java.awt.Window.dispatchEventImpl(Window.java:1774)
     at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
- if i boot without the card plugged, i'm enable to have serial monitor, i've got the mesage above.
>:( :-X :-/
it was working fine in arduino003.  :'( snif
it look so simple in v003 and so complex with 004.
sorry i'm on G4 not on Intel ;)
eric
mellis
Hmm, "You may also need to remove the contents of /var/spool/uucp".  So says Processing, anyway.
Also, can you post the output of typing at the Terminal: groups
And: ls -la /var/lock
And: ls -la /var/spool/uucp
mrbbp
for groups
Code: [Select]
mrpow appserveradm uucp appserverusr admin
ls - la /var/lock
Code: [Select]
drwxrwxr-x    4 root   uucp   136 May  1 00:34 .
drwxr-xr-x   25 root   wheel  850 May  1 01:25 ..
-r--r--r--    1 mrpow  uucp    11 May  1 00:12 LK.002.009.000
-r--r--r--    1 mrpow  uucp    11 Apr 30 23:55 LK.002.009.002
/var/spool/uucp
Code: [Select]
drwxrwxr-x   14 root   uucp   476 May  1 00:35 .
drwxr-xr-x    8 root   wheel  272 Oct 20  2005 ..
-r--r--r--    1 mrpow  uucp    11 May  1 00:35 LK.002.009.010
-r--r--r--    1 mrpow  uucp    11 Apr 30 21:41 LK.002.009.012
-r--r--r--    1 mrpow  uucp    11 Apr 19 12:17 LK.002.009.014
-r--r--r--    1 mrpow  uucp    11 Apr 19 15:38 LK.002.009.016
-r--r--r--    1 mrpow  uucp    11 Apr 19 15:46 LK.002.009.018
-r--r--r--    1 mrpow  uucp    11 Apr 19 16:27 LK.002.009.024
-r--r--r--    1 mrpow  uucp    11 Mar 17 02:56 LK.002.009.026
-r--r--r--    1 mrpow  uucp    11 Apr 19 17:01 LK.002.009.028
-r--r--r--    1 mrpow  uucp    11 Apr 19 18:01 LK.002.009.032
-r--r--r--    1 mrpow  uucp    11 Apr 20 09:53 LK.002.009.036
-r--r--r--    1 mrpow  uucp    11 Apr 20 10:47 LK.002.009.038
-r--r--r--    1 mrpow  uucp    11 Nov 23 01:29 LK.003.009.000
hope this will help
eric
mellis
You may need to delete all the files in /var/spool/lock.  From the Terminal, run: open /var/spool/lock
Then select all the files and delete them - you may need to authenticate.
mrbbp
i've deleted all the files in /var/spool/uucp
and it seems to work.
i've no folder /var/spool/lock
in /var/spool/ :
Code: [Select]
cups    fax     mqueue  postfix samba   uucp
regards
eric
