Topic: Analog Voltage Reader (Read 568 times) previous topic - next topic
Jaker30528
I'm sure this is a really simple answer but I'm completely forgetting it as I haven't worked on my Arduino in a month. What would the code be if I wanted one of my analog inputs read a voltage coming in. Not from a sensor or anything, just a voltage. It's going to be the voltage from my power supply so my robot will alert me when it's running out of battery. Any help would be great!
Thanks! :)
SystemX
Here is the key lines of code that you will need:
temp = analogRead(in_pin);
val =(float)temp * .0049 ;// val needs to be a float
There is 1023 steps when you analog read, every step is .0049 volts.
If your power supply will give more then 5 volts, you should divide the voltage with resistors(http://en.wikipedia.org/wiki/Voltage_divider).
If you divide your voltage in 3 or 2, you should multiply val by 3 or 2.
Hope I helped.
