Topic: Analog Inputs (Read 738 times) previous topic - next topic
floradesol
Sep 28, 2009, 06:48 pm Last Edit: Sep 28, 2009, 06:51 pm by floradesol Reason: 1
I am planning to use standalone Atmega328.. In its datasheet it had Port C, i.e analog pins of arduino, as bidirectional input/output pins.
So i have made the board with analog inputs to 28 ,27 pins .. analog outputs to 26,25,24 pins... which corresponds to arduino analog pins(0-5)
Will i be able to use analog pins(0-5)  in arduino for both input and output????
thanks!!!
Grumpy_Mike
Quote
I think you are confused. the analogue inputs are on pins 23 to 28 corresponding to analogue input pins 0 to 5.
These can be used as digital input / output as well.
Quote
These are NOT analogue outputs.
floradesol
Hi Grumpy,
Thanks.. This clears my doubt.. So pins 23 to 28 can be used as digital pins as well.. thanks!!
