Topic: Accelerometer (Read 2106 times) previous topic - next topic
atikot
hi!
i'm trying to run arduino (with atmega328) with Accelerometer freescale MMA7260, i bought the accelerometer with sureelectronics pcb board
i've connected the gnd to gnd, vdd to 3v3, X to analog 00, Z to analog 01, and y to analog 02.
here is the code of the program:
static int Xaxis = 0 ;
static int Yaxis = 0 ;
static int Zaxis = 0 ;
static int Xaxisold = 0 ;
static int Yaxisold = 0 ;
static int Zaxisold = 0 ;
static int Xaxisold1 = 0 ;
static int Yaxisold1 = 0 ;
static int Zaxisold1 = 0 ;
Xaxis = analogRead(0);
if(Xaxisold != Xaxis)
 Xaxisold1 = Xaxis;
 Xaxis -= Xaxisold;
Serial.println("X =");
Serial.println(Xaxis);
Xaxisold = Xaxisold1;
//Serial.print(Xaxis, BYTE);
delay(10);
Zaxis = analogRead(1);
if(Zaxisold != Zaxis)
  Zaxisold1 = Zaxis;
   Zaxis -= Zaxisold;
Serial.println("Z =");
Serial.println(Zaxis);
Zaxisold = Zaxisold1;
delay(10);
Yaxis = analogRead(2);
if(Yaxisold != Yaxis)
 Yaxisold1 = Yaxis;
   Yaxis -= Yaxisold;
Serial.println("Y =");
Serial.println(Yaxis);
Yaxisold =  Yaxisold1;
delay(100);
here is the output:
X =
191
Z =
24
Y =
23
X =
-1
Y =
-1
Y =
1
X =
1
X =
-1
Y =
-1
Z =
1
X =
1
Y =
1
X =
-1
Y =
-1
no matter how i move it , it seems like it doesn't responds and there's just noise, does any one know's what im i doing wrong?
atikot
http://www.sure-electronics.net/DC,IC%20chips/DC-SS009_1_b.jpg - here is t he picture of the board
AWOL
How is the sleep mode pin connected?
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
atikot
the sleep pin is not connected, do i have to connect it? right now i have no need in sleep mode
AWOL
#4
Jan 02, 2010, 03:54 pm Last Edit: Jan 02, 2010, 03:55 pm by AWOL Reason: 1
You need to make sure there's a HIGH on the sleep mode pin, otherwise the device will be in sleep whether you want a sleep mode or not.
atikot
ok, thanks! i'll give it a try, so i just need to connect it to digital pin and set it to high?
AWOL
According to the datasheet, yes, that should do the trick.
atikot
ok, it looks like it works, but i get a lot of noise with random peaks sometimes to about 50, is there anyway to handle the noise?
PaulS
Quote
Wear ear-plugs?
You could take several readings, and average the readings. This way, the noise only minimally affects the overall average.
