Topic: wont upload anymore (Read 2679 times) previous topic - next topic
PAULPAUL
hi
my problem is - when i load a program on to my arduino board it doesnt seem to work.  the same program use to work but now doesnt.
below is the error message
Quote
 *     |  Arduino Experimentation Kit Example Code             |
 *     |  CIRC-02 .: 8 LED Fun :. (Multiple LEDs)   |
 *  A few Simple LED animations
 * For more information on this circuit http://tinyurl.com/d2hrud
//LED Pin Variables
int ledPins[] = {2,3,4,5,6,7,8,9}; //An array to hold the pin each LED is connected to
                                   //i.e. LED #0 is connected to pin 2, LED #1, 3 and so on
                                   //to address an array use ledPins[0] this would equal 2
                                   //and ledPins[7] would equal 9
 * setup() - this function runs once when you turn your Arduino on
 * We the three control pins to outputs
  //Set each pin connected to an LED to output mode (pulling high (on) or low (off)
  for(int i = 0; i < 8; i++){         //this is a loop and will repeat eight times
      pinMode(ledPins,OUTPUT); //we use this to set each LED pin to output
  }                                   //the code this replaces is below
  /* (commented code will not run)
   * these are the lines replaced by the for loop above they do exactly the
   * same thing the one above just uses less typing
  pinMode(ledPins[0],OUTPUT);
  pinMode(ledPins[1],OUTPUT);
  pinMode(ledPins[2],OUTPUT);
  pinMode(ledPins[3],OUTPUT);
  pinMode(ledPins[4],OUTPUT);
  pinMode(ledPins[5],OUTPUT);
  pinMode(ledPins[6],OUTPUT);
  pinMode(ledPins[7],OUTPUT);
  (end of commented code)*/
 * loop() - this function will start after setup finishes and then repeat
 * we call a function called oneAfterAnother(). if you would like a different behaviour
 * uncomment (delete the two slashes) one of the other lines
void loop()                     // run over and over again
  oneAfterAnotherNoLoop();   //this will turn on each LED one by one then turn each off
  //oneAfterAnotherLoop();   //does the same as oneAfterAnotherNoLoop but with much less typing
  //oneOnAtATime();          //this will turn one LED on then turn the next one on turning the
                             //former off (one LED will look like it is scrolling along the line
  //inAndOut();              //lights the two middle LEDs then moves them out then back in again
 * oneAfterAnotherNoLoop() - Will light one LED then delay for delayTime then light
 * the next LED until all LEDs are on it will then turn them off one after another
 * this does it without using a loop which makes for a lot of typing.
 * oneOnAtATimeLoop() does exactly the same thing with less typing
void oneAfterAnotherNoLoop(){
  int delayTime = 100; //the time (in milliseconds) to pause between LEDs
                       //make smaller for quicker switching and larger for slower
  digitalWrite(ledPins[0], HIGH);  //Turns on LED #0 (connected to pin 2)
  delay(delayTime);                //waits delayTime milliseconds
  digitalWrite(ledPins[1], HIGH);  //Turns on LED #1 (connected to pin 3)
  digitalWrite(ledPins[2], HIGH);  //Turns on LED #2 (connected to pin 4)
  digitalWrite(ledPins[3], HIGH);  //Turns on LED #3 (connected to pin 5)
  digitalWrite(ledPins[4], HIGH);  //Turns on LED #4 (connected to pin 6)
  digitalWrite(ledPins[5], HIGH);  //Turns on LED #5 (connected to pin 7)
  digitalWrite(ledPins[6], HIGH);  //Turns on LED #6 (connected to pin 8)
  digitalWrite(ledPins[7], HIGH);  //Turns on LED #7 (connected to pin 9)
//Turns Each LED Off
  digitalWrite(ledPins[7], LOW);  //Turns on LED #0 (connected to pin 2)
  digitalWrite(ledPins[6], LOW);  //Turns on LED #1 (connected to pin 3)
  digitalWrite(ledPins[5], LOW);  //Turns on LED #2 (connected to pin 4)
  digitalWrite(ledPins[4], LOW);  //Turns on LED #3 (connected to pin 5)
  digitalWrite(ledPins[3], LOW);  //Turns on LED #4 (connected to pin 6)
  digitalWrite(ledPins[2], LOW);  //Turns on LED #5 (connected to pin 7)
  digitalWrite(ledPins[1], LOW);  //Turns on LED #6 (connected to pin 8)
  digitalWrite(ledPins[0], LOW);  //Turns on LED #7 (connected to pin 9)
 * oneAfterAnotherLoop() - Will light one LED then delay for delayTime then light
 * this does it using a loop which makes for a lot less typing.
 * than oneOnAtATimeNoLoop() does exactly the same thing with less typing
void oneAfterAnotherLoop(){
//Turn Each LED on one after a
Coding Badly
Give this a try....
Code: [Select]
//LED Pin Variables
* setup() - this function runs once when you turn your Arduino on * We the three control pins to outputs
     pinMode(ledPins[i],OUTPUT); //we use this to set each LED pin to output
 //oneOnAtATime();
 //inAndOut();
 //Turn Each LED on one after another
 for(int i = 0; i <= 7; i++)
   digitalWrite(ledPins[i], HIGH);  //Turns on LED #i each time this runs i
   delay(delayTime);                //gets one added to it so this will repeat
 }                                  //8 times the first time i will = 0 the final
                                    //time i will equal 7;//Turn Each LED off one after another
 for(int i = 7; i >= 0; i--)   //same as above but rather than starting at 0 and counting up
                               //we start at seven and count down
   digitalWrite(ledPins[i], LOW);  //Turns off LED #i each time this runs i
   delay(delayTime);                //gets one subtracted from it so this will repeat
  }                                  //8 times the first time i will = 7 the final
                                    //time i will equal 0;
* oneOnAtATime() - Will light one LED then the next turning off all the others
void oneOnAtATime()
   int offLED = i - 1;  //Calculate which LED was turned on last time through
   if(i == 0)           //for i = 1 to 7 this is i minus 1 (i.e. if i = 2 we will
     offLED = 7;        //turn on LED 2 and off LED 1)
   }                    //however if i = 0 we don't want to turn of led -1 (doesn't exist)
                        //instead we turn off LED 7, (looping around)
   digitalWrite(ledPins[i], HIGH);     //turn on LED #i
   digitalWrite(ledPins[offLED], LOW); //turn off the LED we turned on last time
   delay(delayTime);
* inAndOut() - This will turn on the two middle LEDs then the next two out
* making an in and out look
void inAndOut()
 //runs the LEDs out from the middle
 for(int i = 0; i <= 3; i++)
     offLED = 3;        //turn on LED 2 and off LED 1)
   int onLED1 = 3 - i;       //this is the first LED to go on ie. LED #3 when i = 0 and LED #0 when i = 3
   int onLED2 = 4 + i;       //this is the first LED to go on ie. LED #4 when i = 0 and LED #7 when i = 3
   int offLED1 = 3 - offLED; //turns off the LED we turned on last time
   int offLED2 = 4 + offLED; //turns off the LED we turned on last time
   digitalWrite(ledPins[onLED1], HIGH);
   digitalWrite(ledPins[onLED2], HIGH);
   digitalWrite(ledPins[offLED1], LOW);
   digitalWrite(ledPins[offLED2], LOW);
   delay(delayTime);
 }  //runs the LEDs into the middle
 for(int i = 3; i >= 0; i--)
   int offLED = i + 1;  //Calculate which LED was turned on last time through
   if(i == 3) {         //for i = 1 to 7 this is i minus 1 (i.e. if i = 2 we will
     offLED = 0;        //turn on LED 2 and off LED 1)
   delay(delayTime);
PAULPAUL
Hi thanks for the reply!
I tested that program - didn't work either :(
When I load it up on my arduino this message appears:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
The little orange light on the board with L next to it keeps flashing.  I know the LED's are rigged up right as an old program appears to work on it for a few seconds before stopping.
Any other suggestions?
Thanks
Paul
PAULPAUL
Oh also!
When I press the reset button - the orange light is off while pressing the button down but as soon as I release it, it begins flashing again.
Paul
Coding Badly
Have you selected the correct serial port?
Have you selected the correct board?
PAULPAUL
Ive got the right board selected.  It did work before but maybe I have made a mistake somewhere - it says my serial port is COM7 - how do I change this?
Thanks
Paul
Coding Badly
Quote
The animation runs for a few seconds then stops?
Quote
Start the Arduino IDE.  Click Tools then Serial Port then select the serial port for your board.
PAULPAUL
Yeah it runs then stops and now the LED's have started flashes strangely - does this mean it has crashed? How can I fix that?
For the serial port - the only option is COM7.
Thanks again
Paul
PAULPAUL
I rearranged the pins so that 9 is now 13 and 8 is now 12 etc but the same error message keeps appearing:
Do you think it maybe a problem with the board?
Thanks
Paul
PAULPAUL
Hi
I have just discovered that the problem is with thee ATMega chip - theres another one on the way! Hopefully that will do it!
Thanks
Paul
;D
Coding Badly
Quote
Quote
It is very likely that you passed too much power / current through the processor and damaged it.
Absolute maximum current is 200ma total.  Absolute maximum current per pin is 40ma.  It's best to stay well below half that (100ma / 20ma).
