Topic: wiring.c:83: error: 'timer0_clock_cycles' (Read 880 times) previous topic - next topic
pvtproject
just getting started, bought a POP-BOT from Sparkfun, came with Arduino 0016. Installed the software, connected up to hardware but cannot even seem to get the software running, not a great start!
Here is the error :
C:\Program Files\Arduino\hardware\cores\arduino\wiring.c: In function 'millisSet':
C:\Program Files\Arduino\hardware\cores\arduino\wiring.c:83: error: 'timer0_clock_cycles' undeclared (first use in this function)
C:\Program Files\Arduino\hardware\cores\arduino\wiring.c:83: error: (Each undeclared identifier is reported only once
C:\Program Files\Arduino\hardware\cores\arduino\wiring.c:83: error: for each function it appears in.)
Couldn't determine program size: C:\Program Files\Arduino\hardware/tools/avr/bin/avr-size: 'C:\Users\ANDREW~1.RFD\AppData\Local\Temp\build25990.tmp\BlinkLED.hex': No such file
pretty sure the solution to this is simple...
please help
GrooveFlotilla
#1
Apr 12, 2010, 02:04 pm Last Edit: Apr 12, 2010, 02:05 pm by GrooveFlotilla Reason: 1
I'd ditch 0016 and download 0018.
You didn't say which OS you're using.
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
pvtproject
Vista,
downloaded 0018 today, 0016 came as a setup file whereas 0018 is a zipfile. unzipped all the files. Didn't install like 0016.
run through the verify and it complied, one step closer.
thanks
