Topic: AnalogIn to DigitalIn (Read 1 time) previous topic - next topic
PhillipMorris
Is it possible to turn an analog IN port to digital IN port ?
I need 2 more digital IN for 2 push buttons but I run out of digital ports...
Please help...
GrooveFlotilla
Analogue pin zero is digital pin 14, analogue pin 1 is digital 15, and so on.
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
PhillipMorris
Sorry but I didn't understand.
I am using Arduino Duemilanove with 14 digital IN/OUT and 6 analog IN/OUT. Correct ?
All my digital pins are taken so I need a way to turn an analog pin to digital in order to use it for a push button.
I am quite new to arduino so please help...
GrooveFlotilla
#3
May 10, 2010, 03:51 pm Last Edit: May 10, 2010, 03:52 pm by GrooveFlotilla Reason: 1
When you use the digital pins, you specify, say, a pin number 0 to 13, yes?
When you want to use an analogue pin as a digital pin, you use the analogue pin number plus 14.
So, to set analogue pin zero as a digital input,
Code: [Select]
pinMode (14, INPUT);
PhillipMorris
I think I understand now.
Thanks a lot...
I will give it a try.
herctrap
so on the mega
analog pin 0 is digital read 54?
herctrap
