Topic: Due I2C Nack Attack (Read 1 time) previous topic - next topic
Power_Broker
I tried using the following example sketch to interface with my LidarLite V3 distance sensor on my Due, but all I get in the serial monitor are nacks! On the flip side, the example works perfectly with my Mega.
Circuit stuff: I'm using a TXS0108E level shifter, 2.2K pullups on the 5V I2C lines, 100uF cap on the 5V supply, and a buck converter for the 5V power supply (all grounds connected).
Can anyone else get this code to work with the Due?
Code: [Select]
  LIDARLite Arduino Library
  GetDistanceI2c
  This example shows how to initialize, configure, and read distance from a
  LIDAR-Lite connected over the I2C interface.
  Connections:
  LIDAR-Lite 5 Vdc (red) to Arduino 5v
  LIDAR-Lite I2C SCL (green) to Arduino SCL
  LIDAR-Lite I2C SDA (blue) to Arduino SDA
  LIDAR-Lite Ground (black) to Arduino GND
  (Capacitor recommended to mitigate inrush current when device is enabled)
  680uF capacitor (+) to Arduino 5v
  680uF capacitor (-) to Arduino GND
  See the Operation Manual for wiring diagrams and more information:
  http://static.garmin.com/pumac/LIDAR_Lite_v3_Operation_Manual_and_Technical_Specifications.pdf
#include <Wire.h>
#include <LIDARLite.h>
LIDARLite myLidarLite;
  Serial.begin(115200); // Initialize serial connection to display distance readings
    begin(int configuration, bool fasti2c, char lidarliteAddress)
    Starts the sensor and I2C.
    Parameters
    configuration: Default 0. Selects one of several preset configurations.
    fasti2c: Default 100 kHz. I2C base frequency.
      If true I2C frequency is set to 400kHz.
    lidarliteAddress: Default 0x62. Fill in new address here if changed. See
      operating manual for instructions.
  myLidarLite.begin(0, true); // Set configuration to default and I2C to 400 kHz
    configure(int configuration, char lidarliteAddress)
    Parameters
      0: Default mode, balanced performance.
      1: Short range, high speed. Uses 0x1d maximum acquisition count.
      2: Default range, higher speed short range. Turns on quick termination
          detection for faster measurements at short range (with decreased
          accuracy)
      3: Maximum range. Uses 0xff maximum acquisition count.
      4: High sensitivity detection. Overrides default valid measurement detection
          algorithm, and uses a threshold value for high sensitivity and noise.
      5: Low sensitivity detection. Overrides default valid measurement detection
          algorithm, and uses a threshold value for low sensitivity and noise.
  myLidarLite.configure(0); // Change this number to try out alternate configurations
    distance(bool biasCorrection, char lidarliteAddress)
    Take a distance measurement and read the result.
    Parameters
    biasCorrection: Default true. Take aquisition with receiver bias
      correction. If set to false measurements will be faster. Receiver bias
      correction must be performed periodically. (e.g. 1 out of every 100
      readings).
  // Take a measurement with receiver bias correction and print to serial terminal
  Serial.println(myLidarLite.distance());
  // Take 99 measurements without receiver bias correction and print to serial terminal
  for(int i = 0; i < 99; i++)
    Serial.println(myLidarLite.distance(false));
"The desire that guides me in all I do is the desire to harness the forces of nature to the service of mankind."
   - Nikola Tesla
ard_newbie
SCL0 / SDA0 did have pullups builtin but not SCL1 / SDA1.
On SCL1/ SDA1 you need Pullups about 2k2 Ohm on both (connected to 3.3 V) and replace everywhere wire by wire1.
If you have a long I2C bus, you have ringing on the falling edges, and the clocks coming into your board will have glitches on the order of 50ns. See this thread reply #19 for a workaround:
https://forum.arduino.cc/index.php?topic=358428.15
j_lrn_ard1
I was just wondering if you were you able to get the Lidar Lite to work with your Arduino Due using I2C? I am having the same issues trying to get mine to work. I was successful with it on the Arduino Uno, just not the Due.
