Topic: keypad.addEventListener(keypadEvent); (Read 1 time) previous topic - next topic
Adroham
I'm confused how to fix code and also why that code which is   keypad.addEventListener(keypadEvent); is declared in this scope? someone let me know please
#include <DS3231.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 3;
char keys [ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {8, 7, 6, 5};
byte colPins[COLS] = {4, 3, 2};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
boolean blink = false;
LiquidCrystal_I2C lcd(0x3F, 20, 4);
DS3231 rtc(SDA,SCL);
Time t;
int led1 =13;
  lcd.init();
  lcd.backlight();
  lcd.setCursor(5,2);
  lcd.print("Hello");
  lcd.clear();
  lcd.setCursor(2,0);
  lcd.print("We gotta start!");
  delay(2000);
  lcd.clear();
  lcd.setCursor(5,1);
  lcd.print("Loading.");
  delay(800);
  lcd.clear();
  lcd.setCursor(5,1);
  lcd.print("Loading...");
  delay(800);
  lcd.clear();
  lcd.setCursor(5,1);
  lcd.print("Loading.....");
  delay(800);
  lcd.noBacklight();
  lcd.clear();
  lcd.init();
  lcd.backlight();
  pinMode(led1,OUTPUT);
  rtc.begin();
  rtc.setTime(7,59,55);
  rtc.setDate(22,9,2017);
  void loop(){
  char key =keypad.getKey();
  t = rtc.getTime();
  int cur_date = t.date;
  int cur_month= t.mon;
  int cur_year= t.year;
  int cur_hour=t.hour;
  int cur_min=t.min;
  int cur_sec=t.sec;
  lcd.setCursor(0,0);
  lcd.print(cur_year);
  lcd.print("-");
  lcd.print(cur_month);
  lcd.print("-");
  lcd.print(cur_date);
  lcd.print("  ");
  lcd.setCursor(11,0);
  lcd.print(cur_hour);
  lcd.print(":");
  lcd.print(cur_min);
  lcd.print(":");
  lcd.println(cur_sec);
  if(cur_hour == 8 && cur_min ==00){
    lcd.setCursor(0,2);
    lcd.print("Get the alarm");
    digitalWrite(led1,HIGH);
    delay(100);
    digitalWrite(led1,LOW);
    delay(100);
  }else{
    String lcd1string= "00";
    String lcd2string= "00";
    String lcd3string= "00";
    lcd.setCursor(0,3);
    lcd.print(lcd1string);
    lcd.print(":");
    lcd.print(lcd2string);
    lcd.print(":");
    lcd.print(lcd3string);
    if(key!=NO_KEY){
    lcd.setCursor(0,1);
    lcd.print(key);
  void keypadEvnet(KeypadEvnet key){
    switch (keypad.getState()){
      case PRESSED:
      case '#' : digitalWrite(ledPin,!digitalRead(ledPin));
      case '*' : digitalWrite(ledPin,!digitalRead(ledPin));
    case RELEASED:
    switch (key){
      case '*':
      blink = false;
    case HOLD:
    switch (key){
      case '*':blink = true;
johnwasser
Code: [Select]
sketch_sep22a:124: error: variable or field 'keypadEvnet' declared void
   void keypadEvnet(KeypadEvnet key) {
sketch_sep22a:124: error: 'KeypadEvnet' was not declared in this scope
sketch_sep22a:148: error: expected '}' at end of input
I think it's because you spelled "Event" wrong.  Try "KeypadEvent", not "KeypadEvnet".
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
PaulS
Quote
Why do you think the improperly posted code needs fixing?
Quote
What scope do you think it should be "declared" in? Code is not declared. Variables are.
If you foolishly insist on putting the { on the line with the function declaration or the if statement, atleastusesomespacesoitisrecognizable.
